wheelentime
So i finally got my bronco running and timed. and i have been having to starting it by dumping a bit of fuel in the carb to get it to start each time. didnt think anything of it untill i finaly got it it timed and running good, and then came out a couple days later to take it for a spin and it wouldnt start. but after dumping a bit of fuel in the carb it fired right up. after i asked a masterr tech friend he said sounds like the fuel pump. so i changed it and well it still wont pick up fuel. not sure what the deal is. my friend said it could be the mechanisam inside the block thats not allowing the fuel pump to work. the part that actally moves the arm on the fuel pump. has any one had this issue? or maybe know of another reason its not working? before I change to a electic fuel pump? FYI. tank is full, and i have new fuel filters. so i know nothings clogged because it also runs fine once i get it going from dumping fuel in the carb.
