Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 09/22/13, 01:24 PM   #1
Airmapper
Foolproofness Tester
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
Clutch linkage questions
I'm hooking my clutch pedal back up, and between the franken-fab arrangement prior, and me not having the best recollection of taking it apart, I need a second opinion.
A diagram would help, but I haven't found one that really shows what I'm working with.
From the pedal to the lever, I should be in good shape. Today I got a new JB fab clutch rod and bushings installed and it seems to fit fine now.
I have one bolt holding a bracket on the bell housing. A second hole with sleeve appears to at one time allowed a bolt to attach to the block. Mine however has no hole for this second bolt. As it is now, that bracket is "floating" in space bolted on one end and the other is holding on the lever rod that transfers the pedal motion. (The one with the felt washer and round bushings.)
An additional bit of info is I have an 80's 302, and I believe the '70 Bronco's original bell housing.
Does anyone have any ideas if this is fine to use or not? Personally I'd like it to be a bit more secure.
Additionally, I hooked up the rod that goes from the lever to the paddle for the throwout bearing. It has a large D shaped hole, and the lever has a round pin. The cotter pin holds in on, but there is slop in it, what am I supposed to do there?
Thanks for any assistance, if photos are needed I'll try to grab some, I forgot to take my camera when I was working earlier.
-Travis
Early 1966 U14, All Stock, Uncut, 170cid I6 '66 Photo Album
1970 U15, NP435, D20, 302cid V8, 33" KM2's '70 Photo Album
Airmapper is offline   Reply With Quote
Old 09/22/13, 01:41 PM   #2
thegreatjustino
Red Head Grease Monkey
thegreatjustino's Avatar
Vroom Vroom
Stockton, CA
At some point, Ford stopped casting the hole for the clutch linkage into the blocks. I'm assuming because everything went to hydro clutches and it was no longer necessary.
If you have one of these blocks, you'll need the adapter bracket that Wildhorses sells:
http://www.wildhorses4x4.com/product...ersion_Bracket
'When my Bronco is finished' is only a hypothetical statement.
thegreatjustino is offline   Reply With Quote
Old 09/22/13, 04:19 PM   #3
Airmapper
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
Thanks Justin, that looks like it will fix my issue. Didn't even think to look for a conversion part.
Anyone have tips on the push rod interface being sloppy?
-Travis
Old 09/25/13, 07:59 AM   #4
Airmapper
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
My adapter bracket is on it's way.
Is there supposed to be looseness in the connection between the D shaped hole in the push rod and the round pin on the lever?
-Travis
Old 09/25/13, 09:22 AM   #5
70_Steve
Old Guy
70_Steve's Avatar
If You're Going to Do It, Over-do It
Phoenix, AZ
Do you have the clutch return spring installed? Goes between the little hole in the end of the clutch fork and a corresponding little hole on the back side of the motor frame mount.
http://www.tomsbroncoparts.com/produ...ord-bronco-new
'70 Sport, 351W EFI, NV4500, D20 w/Teralows, 4.56s Dana 44 w/Ox and 9" 31 spline Detroit, 35" KM2's, 3 1/2" lift, 2" body lift, 4x4x2 PS, some other stuff I forgot about...
"If it's got tits or tires it's gonna be a problem"
70_Steve is offline   Reply With Quote
Old 09/25/13, 09:37 AM   #6
Airmapper
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
Yes, I pretty much have everything in place, I'm just concerned with the mismatch between the large odd shaped hole on the push rod being held by a smaller round rod on the lever. It's not a smooth interface. The rest of my linkages are nice and tight, except that one.
Here, I drew a sketch of what is going on there.
-Travis
Old 09/25/13, 09:41 AM   #7
DuctTape
DuctTape's Avatar
Bozeman, MT
There is a bushing that goes in that joint, is that your issue? I actually think I have an extra one in my parts box I'm not bothering returning, I could drop it in the mail to you if you like.
I don't necessarily agree with everything I say.
DuctTape is offline   Reply With Quote
Old 09/25/13, 10:18 AM   #8
Airmapper
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
Yes! That is my issue. It never had one to begin with so I didn't know what went on there. At least it's not as bad as I feared thinking I had mismatched parts.
I'll try to find one local, but so far NAPA doesn't list anything like that. I may have to take you up on your offer if I can't find it quicker. I appreciate it either way though, thanks.
-Travis
Old 09/25/13, 10:44 AM   #9
Airmapper
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
Is this it?
-Travis
Old 09/25/13, 01:18 PM   #10
DuctTape
DuctTape's Avatar
Bozeman, MT
Is this it?
Can't tell for sure just from pic. I think this is it:
http://www.wildhorses4x4.com/product..._Bushings_Pair
Old 09/25/13, 01:19 PM   #11
DuctTape
DuctTape's Avatar
Bozeman, MT
Belay that, might indeed be this:
http://www.wildhorses4x4.com/product...sh_Rod_Bushing
I'd have to go look at assembly again to be sure.
Old 09/25/13, 10:26 PM   #12
DirtDonk's Avatar
San Jose, CA
Second one is correct.
As you can see, it's not hard to imagine why very few people have ever seen an original one on their trucks!
The clutch is under quite a bit of pressure and those things wear out quickly.
It may even still be a bit of a loose fit with the new one in there, but at least it won't be as bad as it is now.
Heck, once long ago I found a rubber grommet that I used in mine for a nice tight fit! Now that I think about it, that lasted for a long time. Maybe there's not as much pressure and wear as I was thinking?
Just grease everything up good too. Yeah, it collects dust and dirt, but I always like a well lubed linkage.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
DirtDonk is offline   Reply With Quote
Old 09/26/13, 05:24 AM   #13
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
Original Owner
Ridgefield WA
I thought that bushing looked a little cheesy too. You can replace all the bushings in the clutch linkage including that eye with 3/8" heim joints. It makes the clutch operate smoother.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline   Reply With Quote
Old 09/26/13, 05:24 AM   #14
Airmapper
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
Thanks guys.
Given what you said Paul, I think it might be worth my effort to try something a little different. It may or may not work, but for no more effort than it will take, it's worth a try.
It may be next week but I'll post back if it works. I don't want to get my hopes up till I measure the parts and see what kind of volume I have to work with.
-Travis
Old 09/26/13, 05:38 AM   #15
Airmapper
Airmapper's Avatar
Big Blue Bronco
Bowling Green, KY
eBay: escape4x4
Thanks, I hadn't thought of that, I may try that if my other idea doesn't work, or doesn't last long.
I got a JB fab rod from the pedal to the lever, it has those heim joints on it.
-Travis
Thread Tools
Page generated in 0.33773 seconds with 57 queries
