Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 10/10/13, 11:47 AM   #1
farmerjohn
door opening fix
Hello Again, I bought an incomplete '77 project, w no doors installed and went to work on it. Before welding in my floor pans , i measured my door openings and found them wider at the top.....like by an inch on the drivers side and 3/4"on the passenger side. I have the front fenders and grill removed , top off ,doors off,dash out, sitting on new body bushings and 2"body lift. Any sugestions on how to square up the openings? I know the Bronco was in a wreck and has a different front clip welded on.... My first thoughts were to cut loose the front clip, pull the front door posts in to spec, brace them, then reattach the front clip. My second thought was to ask you guys. Whatcha think? Oh and thanks for your time!
'77, 351W, C-4, Atlas 2, Cage 5.5, 2"body lift, 37's , beadlocks, Detroit locker, 4:88s....
farmerjohn is offline   Reply With Quote
Old 10/10/13, 01:52 PM   #2
sp71eb
sp71eb's Avatar
North Liberty, Ia
You can try shimming the rear two body mount locations to get the fit you want. Just ge some washers that are the same size as the ones above the body mounts and try putting them in differnt locations to get the fit you want.
Si vis pacem, para bellum
sp71eb is offline   Reply With Quote
Old 10/10/13, 04:15 PM   #3
Rustytruck
Rustytruck's Avatar
honest the bolder ran under me
El Monte CA
I would try shimming up the bodymounts at the front of the foot well and shim up the rear body mounts and then pull down the body mounts between the 2 sets you shimmed. The body tub is soft and easy to move at the back of the door opening. Make sure you use a square between the top of the outside of the rocker and the front of the rear fender pannel. don't go past making that square.
Rustytruck is offline   Reply With Quote
Old 10/10/13, 07:35 PM   #4
farmerjohn
ok.... damn, that sounds a heck of a lot easier than all the cutting and welding I mentioned above! I'll give it a try. Thanks!
Old 10/11/13, 02:18 PM   #5
JohnJohn
JohnJohn's Avatar
77 Ranger Frame Off
Leesburg, VA
Ditto on the washers.
It also matters how tight you make each body bolt. You can fix some gaps by just tighting a body bolt and squishing the bushing a tad bit more than others.
77 Ranger 5 year frame off nut and bolt restoration by me with EFI, 4.11s, Cage 3.5" lift 2" body lift, MTZ 35s on 17" Allied Monster Beadlocks, Duff Long Arms, BC TRO, Kiser Riser, Protofab bumpers, Warn winch. 1970 Trail rig with 37's on Trail Worth Fab H1 beadlocks, long arms, 302, C4.
JohnJohn is offline   Reply With Quote
Old 10/11/13, 05:30 PM   #6
Billsboat
Billsboat's Avatar
It's nice to be important, but it is more important to be nice
Rowlett tx
I recently did this to my 71, worked out pretty good, still needs I bit more tweaking.
Billsboat is offline   Reply With Quote
Thread Tools
Page generated in 0.30220 seconds with 58 queries
