Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 01/12/14, 12:43 PM   #16
pcf_mark
pcf_mark's Avatar
I need to fix this some more until it is broke!
Perkasie, PA
I'm a huge fan of MegaSquirt with the Ford and GM sensors. You can get the parts anywhere, you put it together to so you know it well and you can tune it yourself. There is also a world wide forum of people using it so you can tips and trick and even download tunes. I plan to add a blower and see how far I can take the stock 289 engine using MS as the ECU.
My wife and my Bronco are not friends...
3G, PS, Hydroboost, front discs, 4R70W/NP205/MicroSquirt, forged 5.0 roller w/EDIS/serp/Mustang EFI/MegaSquirt controlling it - all tuned by ME, Hedman headers, Extreme Fab Family cage, H-of-K paint stock body and suspension.
pcf_mark is offline   Reply With Quote
Old 01/12/14, 03:37 PM   #17
ryan287
ryan287's Avatar
Orange County, CA
Originally Posted by bmc69 View Post
Out of idle curiosity more than anything else....do you have any links to what supports that conclusion? I've yet to see much of anything that shows any significant measured (dyno) power difference between carbs, TBI or MPI..
I've been building/using all three for almost 4 decades now; the highest HP motors I've built were carbureted...but unfortunately those do poorly on trail rigs compared to any EFI option.
Multi port fuel injection can be set up sequentially, meaning the only ECU has the injector squirt fuel in very close to the head intake runner on the downstroke before compression on an individual cylinder basis, not as a batch at the throttle body like TBA. This saves fuel.
Most of the performance information has been gathered through calling up the EFI engineers at Holley and Edelbrock. The Motec headquarters is by my house, so I stopped in to talk to them even though their stuff is like $6-10k serious racing stuff. The guy couldn't have been nicer... spent like an hour talking to me. Everybody said the same thing; the injectors are closer to the cylinder, so the atomization and density of the fuel is better than TBI. You can even go farther and individually tune each injector for each runner flow characteristic using exhaust gas temp (egt) and individual wide band O2 sensors on each header exhaust port.
I'm in the midst of going to a Holley HP efi from my old Edelbrock Proflo, so I've been obsessively researching.
420w stroker, Holley HP seq EFI & DIS MSD crank wheel, AFR 185 heads, JBA ceramic shorty headers, WH 3.5" Coils, Deaver 13pk Leafs, Bilstein 5100's, NV4500, Detroit 9" w/31 spline, ARB D44, 4.88's, 35" BFG Muds, Hydroboost, WH Dana 20 High Output Shaft
ryan287 is offline   Reply With Quote
Old 01/12/14, 10:02 PM   #18
Rolltide
Rolltide's Avatar
so you made someone mad? Good, it means you stood up for something in your life
Enterprise, AL
Great tips guys, thanks. I think I like the lightning setup. I've heard from several folks that the mustang electronics were a good option. I'll report back in a month or so with the results.
Now if I can just with the stuff I need off eBay I'll be in business.
Rolltide is offline   Reply With Quote
Old 01/12/14, 11:16 PM   #19
mavereq
mavereq's Avatar
I'm running the FAST EZ EFI and have been really happy with it so far. I had a truck avenger on my 408 and it dynoed really well but now it cranks up first turn without touching the pedal.
mavereq is offline   Reply With Quote
Old 01/13/14, 09:06 AM   #20
kntr
kntr's Avatar
Tuff Truck Racer
Montana
How long have you have the FAST EZ EFI on your bronco?
Is it a set and forget or are you messing with it a lot?
69 Tuff Truck
3.5" lift, extended arms/King Bypass, 8pt cage (tested 6 times), twin stick, 302/370+hp, spooled, 4 link rear/King coilovers, Boggers/Buckshots, battery/radiator in rear, 31 spline rear, Yukon axles/joints, BC Heim steering, King Bumps.
kntr is offline   Reply With Quote
Thread Tools
Page generated in 0.30167 seconds with 55 queries
