Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 10/21/02, 05:00 PM   #1
Lloyd
Broncos Rule!
Williamsburg, Kentucky
95 mustang 302 HO swap
I found a 95 302 HO with 67,000 miles including the wiring harness, headers, and sensors, and possibly the computer for 625. Everything I've read says to go with an 89-93, but this seems to be too good a deal to pass on. It seems the biggest issue with 94-95 is a smaller pool of salvage parts to choose from and a different wiring harness.<br><br>I can possibly get the stuff for a serpentine conversion as well. How hard is this to do. <br><br>It will be a daily driver with a c4 auto trans. I'd like to hear other's stories on efi and what the biggest problems are, hidden costs, etc. <br><br>What about throttle linkage and the kickdown rod?<br>Do motor mounts line up?<br><br>I know this topic has been discussed indepth before, but I haven't been too interested in it until now.<br><br>Any and all advice and opinions would be much appreciated.<br>
Lloyd is offline
Old 10/21/02, 05:21 PM   #2
Hnrys69
Hnrys69's Avatar
1Fine69
Reno, NV
Re:95 mustang 302 HO swap
Your biggest prob will be how wide the motor is. You may need to chop out some inner fender <br><br>If your good with tools, do it
-Andy Henry
69, Blue, EFI Built 302, locked disc D44/warn shafts, BB 9in, C4, BC 3.5in lift, 2in body, 37in MTRs, Weld Typhoons, RS9000's, STC soft top.
Hnrys69 is offline
Old 10/21/02, 05:30 PM   #3
broncobsession
Not a bronco guru
broncobsession's Avatar
All Over the Place
From what I hear, it's the little stuff that gets you (fuel pumps, wiring harness, etc.) I have also heard it is too wide (like Henry said), but if you can figure out the wiring and pick it up for cheap, go for it.
Always looking for the next project.
broncobsession is offline
Old 10/21/02, 05:46 PM   #4
randall25x
Broncos Rule!
Memphis Area
A 95 302 is a 302, a 5.0, whatever you want to call it. It is not a modular motor therefore it is no wider than a 75 302. The modular mustang motor is a 4.6 and started in 96 if im not mistaken.
1973 5.0 SEFI Mass Air, auto,ps,pdb,3.90 gears,etc.....
randall25x is offline
Old 10/21/02, 06:12 PM   #5
Lloyd
Broncos Rule!
It comes with the wiring harness and I can get the control box. How much harder will it be to wire that an 89-93 if I have the harness? 95 was the last year for the 302 so I don't think width should be an issue. Wouldn't the fuel pump and plumbing be the same as the 89-93 swap?
Lloyd is offline
Old 10/21/02, 07:13 PM   #6
rulebreaker
rulebreaker's Avatar
Broncos Rock! Jeeps roll.Bronco's Rule!Jeeps drool
Manton MI
Go for it! Its an easy install! The main difference is the electronics. Worst case senario You get a 89-93 wire harness and computer. Sell the 95 harness &amp; computer on ebay. A 5.0 is a 5.0! The 4.6 is the wide engine. I have installed two 5.0 and one 5.8L EFI and have really enjoyed the challenge. I just wish I knew about this site when I did it.
75 bronco 351Propane/NP435 /dana20 twin stick Driven every day from the first day of spring till the last day of fall, topless as much as I can.
rulebreaker is offline
Old 10/21/02, 07:52 PM   #7
Lloyd
Broncos Rule!
I was wondering if I could use an 89-93 harness/control box if problems occurred. Would I have to use different sensors then that were compatible with that harness? Also, what are the pros/cons of the serpentine belt set up? I read that the 94-95 required the use of an electric fan? I also read that the EGR? sensors were different in 94-95? I'm wondering about that. I'm hoping to install a centech harness at the same time and hoping this will make the install easier. The bronco is completely apart - an empty tub sitting on the frame with no drivetrain. This should be the easiest time to tackle this job.
Lloyd is offline
Old 10/22/02, 05:28 AM   #8
rulebreaker
Manton MI
[quote author=Lloyd link=board=5;threadid=10422;start=0#75757 date=1035251573]<br>I was wondering if I could use an 89-93 harness/control box if problems occurred. Would I have to use different sensors then that were compatible with that harness? Also, what are the pros/cons of the serpentine belt set up? I read that the 94-95 required the use of an electric fan? I also read that the EGR? sensors were different in 94-95? I'm wondering about that. I'm hoping to install a centech harness at the same time and hoping this will make the install easier. The bronco is completely apart - an empty tub sitting on the frame with no drivetrain. This should be the easiest time to tackle this job.<br>[/quote]The EGR may be different but the rest should be the same. I am using all LTD stuff with the Mustang Computer. Minor Wire changes were required but other than that it was straight forward. You can use a standard fan the computer wont know the difference.
Old 10/22/02, 07:38 AM   #9
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
Go for it. That engine should have the short Explorer style belts. This would let you put an Explorer waterpump and fan on it.<br><br>I think they started using the stubby waterpump on the last body style T-bird. Then it was carried over to the Stang. At the end of the 5.0 days with the stang, it went in the Explorer, gaining the fan.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline
Old 10/22/02, 10:01 AM   #10
Lloyd
Broncos Rule!
Can the 94-95 harness and computer be made to work?
Lloyd is offline
Old 10/22/02, 01:28 PM   #11
Adapt and overcome
Maricopa, AZ
If you get everything, go ahead and use the 94-95 harness and ECM. It is all one big happy package. It is pre '96 so you don't have any of theos damn OBDII issues to take care of.<br><br>The question is - did it come from an automatic car? if so, did you get the transmission as well? For the 94+ it should be a computer controled transmission. The ECM may not be happy if it doesn't see a transmission that it expects to be there. On the other hand, a dumb transmission (not ECM controlled) should work fine behind a stick shift computer. and of course a stick will work fine with a stick.
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.29571 seconds with 54 queries
