As usual Cowboy, great work. BC clamps? My system is a little more complicated because I'm running dual tanks so where you have your HP pump, I have 2 filters, a pollak 6 port switch, then a LP pump to feed the HP pump. Can't run a HP pump in the aux tank and both walbro (now TI) and Bosch suggested the in-line pump isn't really a good draw pump through a switch, and the switch has a 45 lb limit so I did this set-up using a carter to draw. HP has to come after the switch since my EFI needs 60 lbs. So after the switch and the carter, the HP pump and another filter to the EFI. I looked at finding hard connectors to everything but it just became a jumble of adapters, and the pollak is plastic so there was no adapter for it. Will run Nicopp as much as I can, but use short pieces of EVAP line as connectors. Not quite as clean, but easy to maintain.
