Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 12/21/02, 04:06 PM   #1
ET
ET's Avatar
Dallas, Tx
eBay: eytenterp
Leaking brake fluid from banjo bolt.
Hey everyone,<br> I need to ask a question for those that has cheby disk convert. I'm in finishing stage of the swap and I notice there are brake fluid leaking from the banjo bolts. I tried tighting the bolt as much as possible and that does not help. I'd tried to use a set of brass washer that came with the calipers and that does not help. Has anyone came across this problem. Any suggest would be great. <br><br>Thanks.
68 oil burner.
ET is offline
Old 12/21/02, 04:11 PM   #2
Jeepster
syracuse
Re:Leaking brake fluid from banjo bolt.
is the mating surface burr free? the brass washers should have done the trick.
Jeepster is offline
Old 12/21/02, 04:29 PM   #3
ET
ET's Avatar
Dallas, Tx
eBay: eytenterp
I did not see any pits or burrs on the caliper or brake block. I'm thinking I might need to get another set of bolts and washers. I just though of something. I had custom brake lines built with a brass block that fit the banjo bolt. Do I need chevy brake line?<br><br>
68 oil burner.
ET is offline
Old 12/22/02, 12:19 AM   #4
howiebilt
Bronco Buddah
howiebilt's Avatar
Broncoholic member and proud of it !!!!!!!!!
Newton
I could be wrong but I think those washers are made of copper and the block should be of a harder material like the original steel block that goes with them . Two softs won't make it quit leaking
DEEP FAITH ELIMINATES FEAR ... On The Trail ...It's howiebilt not howiebought and Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed pharmacist".
howiebilt is offline
Old 12/22/02, 06:34 AM   #5
ET
ET's Avatar
Dallas, Tx
eBay: eytenterp
Your right howie.. It only looks brass. Update. I reread all the conversion websites and my dumb ass missed the chevy brake hose. I don't know why I got some generic hose but when I switch to the chevy hose, no more leaks.
68 oil burner.
ET is offline
Thread Tools
Page generated in 0.28926 seconds with 56 queries
