 Bronco FAQ New
 Vendor Forum New
Bronco Auctions
Go Back   ClassicBroncos.com Forums > Archives > Bronco Talk - Archives
Thread Tools
Old 04/15/03, 07:19 PM   #1
DJM75
DJM75's Avatar
Broncoless :(
Washougal
eBay: DonovanJM
Removing runs in paint
What's the best way to remove runs in paint? Yeah I know sand them out. But I'm looking for a little more detail. Can I sand it out so it still looks go and won't have to repaint? If so how? What type and grain of paper? Any tips are greatly appreciated.
Don
DJM75 is offline
Old 04/15/03, 07:38 PM   #2
ASE-73
Seattle, WA
Re:Removing runs in paint
Eastwood has a "paint skimmer" tool. It is a razor blade tool that removes a controlled thickness of paint (raised run) to the level of surrounding paint. It can then be lightly sanded to perfection.
1973 with 28,000 original miles. Undergoing frame-off restoration to preserve. 351W / NV3550 / Disk Conversion Planned.
ASE-73 is offline
Old 04/15/03, 08:10 PM   #3
2badrotties
Just a Bronco guy !
2badrotties's Avatar
BEWARE of DOGS !
Niskayuna N.Y.
Oh no runs. What kind of paint ? If it is enamel you better let it sit a couple of days. You can use a razor blade with masking tape on the corners so it does not dig up the paint around the runs.
BLADE
I I 0 I I
I tape I I tape I
I_____I___________________I______I
I hope you can figure out what I did up there. Put the tape on the ends of the blade. Just drag the blade over the run holding it straight against the run ( not at a angle ). Go very easy. A little at a time. Then use some fine sand paper 1000 grit (wet) and go over that with some 1500 (wet) and buff. I'm sory I can't explain a little better than this.
2badrotties is offline
Old 04/15/03, 09:03 PM   #4
DJM75
DJM75's Avatar
Broncoless :(
Washougal
eBay: DonovanJM
Yeah it's enamel. So I should let it sit before I use the razor or before I sand or both? Also do you mean to hold the razor perpindicular to the paint?
Thanks for the help.
Don
DJM75 is offline
Old 04/15/03, 09:14 PM   #5
bpatton74
bpatton74's Avatar
Alamogordo, NM
eBay: bpatton74
I recently painted my Bronco with enamel. I waited about one week to let it cure a bit, then VERY lightly took 3m's 1000 Grit wet dry sand paper, used lots of water with soap, and a sanding block. Check your progress regularly so you don't go all the way through. After this step when you get it so you can no longer see the glossy outline of the run, use LOTS of water and soap and go with 3m's 1500 grit paper lightly for a couple of seconds (just enough to clear the 1000 grit scratches). Then take some fine rubbing compound and rub it out, for the extra shine use some finishing Glaze. I did the above listed steps to my entire Bronco and it came out excellent!!!
1974 Bronco, 302, C-4, F-150 disks, rear disks, 4 1/2 BC lift, 2 in body lift, 35 inch TSL-SX's, F150 4x4 P/S, tilt steering, 6 point roll cage, Detroit front, spooled rear, full width axles, 5.43 gears
bpatton74 is offline
Old 04/15/03, 09:15 PM   #6
67ster
Broncos Rule!
What color is it ? On white or very light colors you may end up with some yellowing in the areas where the runs were . Good luck .
67ster is offline
Old 04/15/03, 09:35 PM   #7
DJM75
DJM75's Avatar
Broncoless :(
Washougal
eBay: DonovanJM
It's red. So it shouldn't yellow. Thanks for all the advice.
Don
DJM75 is offline
Thread Tools
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2013, Jel soft Enter prises Ltd.
Copyright © 1996-2013 All rights reserved. Privacy Statement
