Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 06/23/03, 03:33 PM   #1
TexasBronco
TexasBronco's Avatar
Waterford, MI
eBay: 4x4tex
bending diamond plate
I am making a tunnel cover. I need to know how to bend a nice sharp line. I was thinking to score it on the back side. Heat it up. Then use the edge of a 2x4 to bend against. any other ideas?
It doesn't matter whats on the outside, it's what's under the hood that counts.
TexasBronco is offline
Old 06/23/03, 03:39 PM   #2
Jeepincj7
Jeepincj7's Avatar
Check out Broncoholics.com!
Lake Elsinore, CA
Re:bending diamond plate
Put it in a vice, then bend.
Sure hope its only around 1/8" or less though.
Scotty
72' Sport. 302, Truck Avenger carb, NV4500, Atlas 4.3, 5.13s, detroits, 36" Iroks, Champion Beadlocks, Superiors, CTMs, F150 4x4 box, TRO. yada, yada, yada....
www.broncoholics.com
My RigRater Score: 1002RRv1.0 with a BOA of 28.27
Jeepincj7 is offline
Old 06/23/03, 03:39 PM   #3
teknalee
Guest
Posts: n/a
got a table saw? make a jig!
Old 06/23/03, 03:48 PM   #4
TexasBronco
Waterford, MI
eBay: 4x4tex
Well it is just the aluminum plate. not the steel kind.
Old 06/23/03, 04:30 PM   #5
teknalee
Guest
Posts: n/a
damn.. aluminum huh... i'd be afraid of it cracking.. lots of heat and some slow bending over an angled peice of wood
Old 06/25/03, 10:38 AM   #6
72eb69rich
Newbie
San Jose,Ca.
I would check out the "Eastwood Company" website/catalog. They have a nice array of specialty tools for custom fabricating. I've seen a tool just for bending sheet metal in there that maybe, (MAYBE!) used to bend diamond plate. I would also be careful about the cracking issue as stated above.
72eb69rich is offline
Old 06/25/03, 11:51 AM   #7
77TexasBronc
Broncos Rule!
Baytown Texas
This can get ugly real quick using heat to bend aluminum, you may end up with a huge hole blown right through it. lay it out and mark your pieces and take them to someone with a metal break and have them bend them for you, should only cost a couple of buck and end up with nice straight bends.
"Yes, I am a Broncoholic"
77TexasBronc is offline
Old 06/25/03, 01:19 PM   #8
TexasBronco
Waterford, MI
eBay: 4x4tex
[quote author=77TexasBronc link=board=5;threadid=19154;start=0#msg147538 date=1056563510]
[/quote]
Yeah I am thinking about invading Toby's Garage (the winner of Top Trucks) he has a sheet metal bender, and he could help my weld my roll bar...and all the other stuff we can do to get my bronco set to hit the trails.
Old 06/25/03, 09:21 PM   #9
Wildturkey
BANNED
Coker, Alabama
What ever you do dont heat aluminum and try to bend it.Find someone with a really good sheetmetal brake and bend it backwards.Pressure on the smooth side not the diamond plate.You can get a 90degree bend but dont try to go much futher it will break.
Wildturkey is offline
Old 06/25/03, 10:37 PM   #10
jackteri1
Broncos Rule!
Yucca Valley, Ca
I did a lot of DP on my bronco and was able to do the short peices by scoring them, and then put them in a vise between two piecs of angel iron, and bend them. For larger pieces, you are better off taking it some place where they have a break, and let them do it. I have pics of my bronco on page 45, 4th one down. Have fun.
I bent all of mine except for the dash.
jackteri1 is offline
Thread Tools
Page generated in 0.32208 seconds with 58 queries
