Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 02/23/05, 04:22 PM   #1
74bronc
74bronc's Avatar
Right wing nutjob!
socal
eBay: byubronco
New Demon Off-Road carb
Demon is releasing a new off-road version of their carburetors. This was mentioned in a thread a week or so ago, so I did some research. Here is the press release:
Barry Grant, Inc. is introducing a new range of truck carburetors with cfm ratings from 525 to 850. Available in Road, Speed, or Mighty versions, the Demon Trucker performs impressively both on and off the asphalt, and behaves particularly well at high angles of roll or pitch making it ideally suited to rock crawling. All of the Trucker models are equipped with four-corner idle-metering circuits and a vacuum-secondary pod fitted with a quick-change spring to control the opening rates of the secondary throttle plates.
In addition, the Demon Trucker is equipped with:
Single inlet for simple plumbing
Side-hung float bowls and .110 spring-loaded needle-and-seat assemblies for better fuel control
Custom check valves in the metering circuitry to prevent fuel siphoning when the vehicle is at extreme angles (rock crawling, etc)
Custom crossover vent tube to help prevent fuel from leaking from the float bowls.
Manual or electric choke on Road & Speed series only
Tuning parts interchangeable with other makes
74bronc is offline
Old 02/23/05, 04:38 PM   #2
kwspony
kwspony's Avatar
Lab tested
Roseville
did they quote a price yet?
kwspony is offline
Old 02/23/05, 05:01 PM   #3
74bronc
74bronc's Avatar
Right wing nutjob!
socal
eBay: byubronco
no idea on the price yet or an actual retail release. I am assuming the price will be in the same neighborhood as the Holley Truck Avenger as that is their main competition. I don't know a whole lot about Demon carbs, but I am tempted to try this one and see how it works.
74bronc is offline
Old 02/23/05, 05:36 PM   #4
mountainview68
mountainview68's Avatar
There is no replacement for displacement
yet to be determined
I'll be in line for one of these. I ran a regular road demon on my last Bronco with a 351 and it was great!!! My father in law liked it so much he put one on his small block ford powered austin healy.
mountainview68 is offline
Old 02/23/05, 05:43 PM   #5
BUCKETOBOLTS
BUCKETOBOLTS's Avatar
...was born with nothing and still have most of it left...
Salisbury, NC
Looks and sounds a lot like the Truck Avenger to me. I have not had my hands on a Demon yet, but they all appear to be very Holley like. BG probably tunes the fuel circiuts a little different than Holley that is why people like them. Most Holleys are tuned to the rich and in some cases very rich side for engine safety.
'72 Explorer, TBA...
'76 F250 2wd, 390, NP435, 4.10's...aka Brutus
CarolinaBroncosMember
BUCKETOBOLTS is offline
Old 02/23/05, 06:01 PM   #6
BoltBuster
BoltBuster's Avatar
Now Thats Thinking With Your Dipstick, Jimmy!
Chesapeake,Virginia
Thumbs up
B&G are Superb carbs, you can order them now with all these features or atleast thats what I was quoted last year before they just created a line for them as Offroad Series. They go through a great way of setting up the carb taylored with your drive train. PS I will own one if not two
The B&G carbs run from $360.00 to $700.00, What I have seen for sale in offroad was $360.00 or so, $700.00 if you were planning to put your EB in orbit or skip across the rocks and streams on the trail~
Heres a general copy of the email and reply
Can B&G Carbs be used offroad and in angles? which
series? Thanks Kevin
QUESTIONNAIRE APPLICATION INFORMATION
USE: Off Road and High way
ENGINE
Mfg:Ford
Cubic Inch:351 Windsor
Compression Ratio 9.0:1
HEADS
Mfg: Ford 2v stock
Ported Yes
INDUCTION
Mfg: Polished and Ported Holley idle-5500 rpm, dual plane, non egr
Model:
Type: Dual Plane
Ported No
CAMSHAFT
Mfg:Ford Stock 351W cam
P/N
Flat Tappet Mechanical
Intake Lift
Duration Advertised
Duration @ .050"
Rocker Ratio
Exhaust Lift
Duration Advertised
Duration @ .050"
Rocker Ratio
IGNITION: Stock
Brand
Timing @ Idle
Timing @ Full Advance
EXHAUST
Exhaust Manifolds(currently purchasing headers)
Primary Size
Collector Size
Pipe Diameter 2 1/2
Muffler Type: Flow Master
Muffler Size
FUEL SYSTEM
Gas
Pump Type: Electric
Pump Size
Regulator
Type Ford
VEHICLE Bronco
Type:SUV
Wt. 4450 lbs. GVRW,by itself weighs 3750 lbs
Transmission Auto C6
Number of Gears 3
Trans Brake No
Stall Speed
Rear Tire Size 35"X 15
Gear Ratio 3.50
NITROUS:N/A
On this combination we'd recommend using a 625 Road Demon Jr. P/N
6282010VE. With the side hung style float bowls on these carburetors
they work extremely well in off road, and rock crawler applications.
Thank you
Technical Support
http://www.barrygrant.com/
Barry Grant, Inc.
BG Fuel systems, Demon Carburetion, Nitrous Works, Rush Performance
Filters
1450 McDonald Road
Dahlonega, GA 30533
Phone (706) 864-8544
Fax (706) 864-2206
Mon to Fri 8am to 6pm EST
www.Tidewaterfourwheelers.org
67', 351W, C6/NP-205, Crab Cage, 2" body and 3.5" lift, 35 BFG M/Ts
BoltBuster is offline
Thread Tools
Page generated in 0.30384 seconds with 57 queries
