Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 07/15/05, 08:03 PM   #1
kaisermusic
kaisermusic's Avatar
Underpowered, and loving it!
Chehalis WA
Mystery Government Bronco: Please Tell Me What My VIN Means!!!!
www.designatedmedia.com/broncovin.html
Ok I finally got around to stripping the paint off my vin tag. I have thought for a while that this was a '67, since it has a 67 dash etc. Well, low and behold, I actually don't know what year it is, or for that matter, What the dso code means. It has NO color code. It has a "B" date code, which falls between the 67's "A" designation, and the 68's "C" designation. As I understand it, 68 starts with C right? there is a post on this site somewhere that has a scan of a 68's vin guide and it says it starts with C.
Ok, now the DSO reads: 830106
In my original 1967 shop manulal, is says that 83 is the government DSO spec., and i read on here that the next 4 digits are the S.O. customers digits, and don't tell you much. I hope i am wrong because I would love to know what this bronco was used for!
Now, onto the speedo.....
Has anyone seen one that just has ALT and OIL text instead of the gauges? I haven't, but it is on mine.....
PLEASE HELP!
kaisermusic is offline
Old 07/15/05, 08:31 PM   #2
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
The B date code is correct for 67 as they started with A00,001 and ended with B82,000.
Cant help with any of the other codes
As for your gauges that sounds like some one put in a later model gauge cluster I believe 76/77 clusters are as you describe.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 07/15/05, 08:38 PM   #3
kaisermusic
Chehalis WA
ok what would be the month code for a B13968?
My 1967 shop manual was published in august 1966, and has dates of August A 00,000 - August A 71,999
I wasn't aware they changed the cluster in 76/77. My friend's 76 has the regular cluster, and is all original....
Old 07/15/05, 08:52 PM   #4
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
I dont have the production break down for 67
broncnaz is offline
Old 07/15/05, 08:55 PM   #5
kaisermusic
Chehalis WA
I haven't found anything that shows 67 going to a B designation. Is there a site online that anyone knows of? I have no doubt that 67 went to a B code, but whats with the 13,968? A code leaves off with A 71,999.
Old 07/15/05, 08:58 PM   #6
kaisermusic
Chehalis WA
http://www.bronco.com/pmwiki/pmwiki....lsByBuildMonth
site says nothing about B code?????
Old 07/15/05, 09:04 PM   #7
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
I got mine codes out of a parts interchange manual but I just looked in my JBG catolog and they have the same codes they should also have this on there site if not try the bronco ohio site.
broncnaz is offline
Old 07/15/05, 09:07 PM   #8
kaisermusic
Chehalis WA
i tried bronco ohio and it is the same story. They skip the B codes. tried JBG, but it has no list online that I could find. Anyone else have any idea on this DSO or VIN or anything?
Oh is body code 998 stand for parchment?
Old 07/15/05, 09:15 PM   #9
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
The first 9 could stand for parchment and the 98 should be for Long roof (wagon) for U150 or HD package for U151 models
broncnaz is offline
Old 07/15/05, 09:22 PM   #10
kaisermusic
Chehalis WA
it says u150 so I'm assuming its parchment. My seats are green, but it looks like they were painted
Old 07/15/05, 09:34 PM   #11
cdkaminsky
cdkaminsky's Avatar
Pflugerville
Vin Location?
I did not see this on the thread....read threw quick though...
Is the VIn on the drivers side kickplate? THink it was only there for 66 and 67
Guess that does not mean much - 1 have a 67 I will get my Vin info post when I can ....
cdkaminsky is offline
Old 07/15/05, 09:36 PM   #12
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Definitely need to find someone with a 67 ford shop manual. He's right about the vin on the kick panel I have a 67 body on my 73 and theres a vin plate there 2 bad its 2 hours away right now or I'd take a look at it. Also if you have the round door strikers it should be a 67 as in 68 they went to the oval strikers and they were located lower.
broncnaz is offline
Old 07/15/05, 09:36 PM   #13
kaisermusic
Chehalis WA
I have the 1967 shop manual! Thats why it is so wierd that none of this matches up.
yes it is on the kick panel.
Now what does it mean if a bronco doesn't have a color code? It had to be painted, so did it mean that the color was not a factory ford color?
Does anyone else have a government DSO code?
Old 07/15/05, 09:48 PM   #14
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Maybe we need someone with a manual that was published in 67 instead of 66 that would help I'm sure. I'm not real sure about the paint code but I would think that if its designated as a goverment vehicle they probably didnt paint it so which ever agency ordered it could paint it there own color ie, forest service light green, military olive drab ect.
broncnaz is offline
Old 07/15/05, 09:53 PM   #15
kaisermusic
Chehalis WA
Did the 67 manual have a reprint? As far as I know there was only one version. All were printed the same. Don't quote me on this, but The guy I got mine from on ebay deals in all years of bronco manuals and said there was only this version.
So in the JBG catolog 67 goes to a B code for sure?
Thread Tools
Page generated in 0.33959 seconds with 55 queries
