Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 04/07/06, 08:51 AM   #1
grs44310
grs44310's Avatar
We need a little Chlorine in the gene pool!
Akron, Ohio
eBay: grs44310
302 Intake manifold bolt torque spec?
I'm attempting to solve an intake leak problem that I believe is keeping my engine from idling like it is supposed to. When I removed the manifold the bolts on the drivers side were barely finger tight. (Hummm, maybe that was my problem)
The Chilton's manual says to torque the bolts in two steps 50-60 ft lbs first in the sequence specified then 80-90 ft lbs in the same sequence. The problem is I have broken two different bolts now trying to get to the first setting of 60 ft lbs. Is this the right torque spec? What grade of hardware should I be looking for to replace my busted bolts?
Thanks,
Greg
grs44310 is offline
Old 04/07/06, 09:37 AM   #2
airman
airman's Avatar
simple tricks and nonsense
Gilbert, AZ
I think it depends on the manifold and the bolt. I think those are 3/8 bolts and I doubt they are meant for that much.
I did mine to 28 ft lbs (it called for 25 but it seemed lite so in defiance...) and have no leaks. Just keep re-torquing in the same sequence intil they are set. I must have followed the sequence at least a dozen times to get them tight.
I also bought some good bolts from ARP and have an aluminum intake.
I think maybe the head bolts take the torque #'s that you mentioned above.
75, 351W, Fitech Efi, C4, Tera Low twin stick, Detroits front and rear, 35x12.5x15 BFG Mud Terrain , 5.5" suspension, wristed arm, rotated front yokes, Currie HD 9", Vac Power Disc/Drum
airman is offline
Old 04/07/06, 09:44 AM   #3
Cooter_76
Cooter_76's Avatar
Austin, TX
I was just looking for this info on the Edelbrock website yesterday. I beleive it said 18-24 ft. lbs.
Cooter_76 is offline
Old 04/07/06, 09:54 AM   #4
IowaMike
IowaMike's Avatar
My mind is like a steel trap, too bad it's rusted shut.
Council Bluffs, IA
Just did my 4 bbl intake last week, 18 - 24 as stated. The torques you listed look more like head bolt specs.
So many trucks...so little time.
MSgt USAF (Ret)
IowaMike is offline
Old 04/07/06, 11:00 AM   #5
Paco
Paco's Avatar
Is that a full-size Bronco?
Pueblo, CO
In Chilton's book, #7140, pg.97, intake manifold specs 19-27 ft.lbs, depending on the year.
In Ford's 1974 truck shop manual, intake manifold bolt torque...20-22 ft-lbs
Beer: The cause of and solution to all of life's problems
Paco is offline
Old 04/07/06, 11:18 AM   #6
grs44310
grs44310's Avatar
Akron, Ohio
eBay: grs44310
Ok that makes a heck of a lot more sense for a 5/16-18 bolt. Thank you for the help guys!
grs44310 is offline
Thread Tools
Page generated in 0.28569 seconds with 58 queries
