Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 05/18/06, 05:29 PM   #1
DiggetyDan
DiggetyDan's Avatar
Beverly
Can you mix 10w-30 and 10w40 motor oil?
I just came up from the garage - figured i'd do a quick oil change before heading out for a drive. I thought I had a box full of oil but forgot i had given the wife an oil change a couple weeks back. It turns out I have 2 quarts of 10W-30 and 2 quarts of 10W-40.
Would it damage the engine if I combined these two?
DiggetyDan is offline
Old 05/18/06, 05:44 PM   #2
Apogee
Apogee's Avatar
Cuz that's how I roll.
Tangent, OR
Nope...it'll give you about a 10W-35.
Did you know that 95% of all statistics are made up on the spot?
Apogee is offline
Old 05/18/06, 05:50 PM   #3
DiggetyDan
DiggetyDan's Avatar
Beverly
hehe, thanks apogee.
Old 05/18/06, 06:55 PM   #4
scottmcwms
scottmcwms's Avatar
Longhorns...You call it a mascot, we call it hamburger.
Montgomery, TX
It won't damage the engine if you change the oil again quickly. Never, Never, Never combine oils. Don't even use the same viscosity oil from different manufacturers. There are unique additives for each oil and sometimes they don't play well together when mixed. You will probably be OK, but why risk having to pay $1000 or so to overhaul an engine. Don't do it. Better safe than sorry.
Scott
scottmcwms is offline
Old 05/18/06, 07:07 PM   #5
Jeepster
syracuse
Scott
Are you serious?
If thats the case I've been flirting with disaster for years when i do my monthly *"Polish oil change"
*add a qt when low
Jeepster is offline
Old 05/18/06, 07:12 PM   #6
Hogback
Registered User
Hogback's Avatar
same here. Been doing that to my wifes car since it was new. It's never seen a wrench and it still purrs like a kitten at 200K miles.
now too bad the wife doesn't....
Hogback is offline
Old 05/19/06, 01:21 AM   #7
SaddleUp
BANNED
SaddleUp's Avatar
Nothing like a good stretch!
Vancouver, WA
I'll third that. I have my brand preference but I'll use whatever if necessary to keep oil in them.
SaddleUp is offline
Old 05/19/06, 01:29 AM   #8
rellimgneb
rellimgneb's Avatar
Get Noticed, Get Branded
Reno, Nv
Honestly it's just oil. It just coats metal parts so they can slide on other metal parts without getting too hot. Mixem, matchem, do whatever you want as long as they are lubricated.
My life. The ever consuming object of my being.
http://classicbroncos.com/forums/sho...ht=1st+rebuild
rellimgneb is offline
Old 05/19/06, 02:02 AM   #9
astark
Bronco God
astark's Avatar
Batesville Arkansas
Nice motor pic in your gallery
But I don't think four quarts is enough to change your oil anyway. So go get a case of Castrol 10-40 and a couple of Motor Craft filters
"Deep faith eliminates fear... on the trail" Michael Alan Stark April 14, 1990 - October 28, 2007 My Son, Best Friend and Wheeling Buddy.
astark is offline
Old 05/19/06, 04:10 AM   #10
TJK74
TJK74's Avatar
Newark CA
You will be fine with that. They will mix right in with each other and no harm will be done. Even if you were to mix syn with conventional you'll be fine. If you were to labratory test your oil it will read out as not a true 10w-30 but no harm will be done. Your good.
If your doing this in a pinch cause you need to add oil then go for it but if you can like stated above get yourself 6 or so quarts of what you need when you do it the first time
74 Ranger, 69 351W, C4, 4:11s, 35"MTR's, 3'5"BC/WH, 2" Body, Duffs Stg II hoops/rear shock mounts, twin stick.
www.competitionoils.com
To Order AMSOIL
TJK74 is offline
Old 05/19/06, 04:30 AM   #11
ken75ranger
ken75ranger's Avatar
Troy, NY
eBay: ken_75
That's just what I was thinking!
'75 Ranger- with assorted parts
ken75ranger is offline
Old 05/19/06, 03:43 PM   #12
thegreatjustino
Red Head Grease Monkey
thegreatjustino's Avatar
Vroom Vroom
Stockton, CA
I've mixed oils before but always try to use the same viscosity for all six quarts. If you've ever seen two or more types of oil poured into a clear container, they will separate out. When they are running through the engine, I doubt that it's that big of a deal, but I wouldn't mix them intentionally on any kind of regular basis.
'When my Bronco is finished' is only a hypothetical statement.
thegreatjustino is offline
Old 05/19/06, 04:25 PM   #13
commonlaw
commonlaw's Avatar
Indecision may or may not be my problem...
Seattle
eBay: dahui2
Never had a problem mixing.
Also, I noticed that you are only putting 4 quarts in? Not sure of your set-up but that seems low.
"Lordy I have loved some ladies, and I have loved Jim Beam, and they both tried to kill me, in 1973."
commonlaw is offline
Old 05/19/06, 07:28 PM   #14
astark
Bronco God
astark's Avatar
Batesville Arkansas
I once mixed brand and viscosity, my shirt came out of the dryer wrinkled, I burnt some burgers on the barbeque, I ran out of toilet paper and then left my coupons at home when I went to the store.
Don't take a chance, you need to get more oil anyway and you might as well do it right, as that Bronco is your baby and it deserves the best you can provide.
If you take good care of your Bronco, it will take good care of you, and what you put into that relationship will be reciprocated.
astark is offline
Old 05/20/06, 11:04 AM   #15
DiggetyDan
DiggetyDan's Avatar
Beverly
here's a mystery
My oil level is showing full after only 3 quarts, it's on the higher side of the safe line. I've got a 302 which from the sound of it should take 6? I drained the oil out of the bottom plug - I did notice there was another plug closer to the front of the vehicle on the same pan, does that need to be drained also?
Thread Tools
Page generated in 0.31873 seconds with 58 queries
