Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 05/31/06, 05:28 AM   #1
JCook5003
Newbie
ZF 5 Spd and NP205
I've been searching and reading posts about installing a ZF transmission into an EB and install a NP205 transfer case into an EB, I have an NP205 Transfer Case and can get a ZF transmission for about $200 in the yard in town, seems like the NP205 should bolt right up to the ZF and would eliminate the D20 weak link and the $500 adapter kit.
So has anyone ever done this? What else do I need to consider, other possibly a custom cross member?
Also will I need anything new to go with the ZF or will it bolt right in? I read something somewhere about a new master cylinder but dont understand why you would need that to go with a new transmission.......
Hope to get some good advice from everyone here.
Josh
JCook5003 is offline
Old 05/31/06, 06:11 AM   #2
SaddleUp
BANNED
SaddleUp's Avatar
Nothing like a good stretch!
Vancouver, WA
The 205 should bolt right up. You will need to build a custom cross member for it though and work through the linkage to build a new shifter (Perhaps twin stick it). If you can get a 4WD ZF for $200 jump all over it. The master cylinder you need is for the clutch not the brakes. The ZF uses a hydraulic rather than mechanical clutch. This requires a clutch master cylinder on the firewall and then a slave cylinder on the tranny with a hydraulic line between them. FWIW, I was considering this swap at one point but I planned to do a 203 doubler at the same time.
SaddleUp is offline
Old 05/31/06, 06:33 AM   #3
JCook5003
Newbie
So can you offer any advice on which master cylinder should work, should I grab the one off the donor truck or do I need an aftermarket part?
Old 05/31/06, 07:08 AM   #4
trailpsycho
trailpsycho's Avatar
Indianapolis
Make sure its not a 2WD ZF. Thats all I was able to find around here. The tranny rebuilders/remanufacturers tend to get them well before the trucks ever hit the yard. Good luck. Check out BC Broncos, they have some parts for adapting the ZF into a Bronco (crossmember, slave/master cylinder kits, etc.).
trailpsycho is offline
Old 05/31/06, 07:35 AM   #5
SaddleUp
BANNED
SaddleUp's Avatar
Vancouver, WA
Personally I would try to use the stock one from the truck first.
SaddleUp is offline
Old 05/31/06, 07:54 AM   #6
JCook5003
Newbie
The stock bronco unit or the unit from the truck I am pulling the Transmission from? Also I know it's a 4x4 truck the unit is still in it
Old 05/31/06, 08:14 AM   #7
SaddleUp
BANNED
SaddleUp's Avatar
Vancouver, WA
There isn't a stock bronco unit. The Bronco used mechanical linkage for the clutch rather than hydraulic.
SaddleUp is offline
Old 05/31/06, 09:03 AM   #8
daddyg
Bronco Parts Collector
daddyg's Avatar
Bronco Master Wannabe
Harvest, AL
What SaddleUp is saying is that you will have two master cylinders. One for the clutch and one for the brakes. Get the clutch master cylinder from the donor truck.
74 - (Smokey) Trail rig owned for 26 years
76 - (Spirit) Street / Trails
73 Ranger - (Ricky) All stock
daddyg is offline
Old 05/31/06, 09:09 AM   #9
JCook5003
Newbie
oh ok gotcha, I understand now, the more I think about it the more this swap seems possible.
Old 11/13/06, 10:21 PM   #10
hammer
hammer's Avatar
Broncos eh?
Abbotsford, B.C.
eBay: hmr_tym
So JCook did you get this done. Found this old post in a search because its the exact question I was looking to ask. I knew about the master cylinder, but I'm interested as to how you made out with np205. I've heard that its to wide to fit between the eb's framerails. I don't understand why anyone would pay that kind of money to mate their d20 up to the zf if this is easy. I'm kinda in the opposite position where I already have a 4wd zf, just wondering if the np205 is my way to go.
hammer is offline
Old 11/14/06, 07:08 PM   #11
MpCrewcab
MpCrewcab's Avatar
The Ford Truck Doctor
Jefferson, WI
zf-205
I have a zf and a 205 in a bronco I am building I will see if we have any pics of it. The 205 just bolted on but had to trim a little for the shift rails but the 205 fits perfect but not any room to spare and I used the tcase mount from the 79 bronco just flipped it. Mike
MpCrewcab is offline
Old 11/15/06, 01:04 AM   #12
hammer
hammer's Avatar
Broncos eh?
Abbotsford, B.C.
eBay: hmr_tym
So are you running tranny and t-case crossmembers? I've seen some pics on here of guys using the side mount of the np205.
hammer is offline
Old 11/15/06, 04:37 PM   #13
daj
No one seemed to mention the ZF must be out of a small block 351 or a I-6.I have found loads of them for the 460s.
d
daj is offline
Old 08/07/08, 04:48 AM   #14
z-one311
Payson, Utah
eBay: z-one311
ZF swap!
I just sold one and have another i am selling. It will bolt right up to the 205 but you have to modify the rear of the zf jsut a little bit to make the shift linkage work like original. Or you can change you shift linkage on the 205 and thats it. It is the same spline count as the 205 transfer case input. And all of the zf trans will fit the 205. The 5.8/7.3/7.5, 302/351/460/7.3 deisel. But the only one that will work ing your bronco set up with the 302/351 is the one out of a 5.8/5.0 f250/f350! i am selling this one for 600 plus 150 shipping!
z-one311 is offline
Old 08/08/08, 08:28 AM   #15
JB Fab
JB Fab's Avatar
The doctor said "if it hurts, don't do it"
Salem, Oregon
Here are a couple of pictures that one of our customers sent us of that combo with our stainless NP-205 twin-sticks....
Jon
JB CUSTOM FABRICATION LLC
www.jbfab.net
JB Fab is offline
Thread Tools
Page generated in 0.32345 seconds with 57 queries
