Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 06/30/06, 03:53 PM   #1
Blue71
Blue71's Avatar
Broncos Rule!
Johnson City, TN
How to remove old bed liner?
Has anyone found a product or method that removes roll on bed liner? I am thinking about stripping a tub and need this old roll on Herculiner type stuff off. Chemical to desolve it? ? Blasting it? Any hints?
Thanks Much,
Blue71
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'76 Explorer w/ Four Wheel Pop-up Camper
'77 Wagon
'77 Original Ranger, 76,000 mi
"Yes I Know, But When Do I Get To Drive That Thang"
Blue71 is offline
Old 06/30/06, 04:41 PM   #2
72Sport
Work is a four letter word.
SoCal
I don't know where I saw it but somewhere I read to use oven cleaner. I remember the post or article said don't buy the cheap stuff because it won't work. It was not Easy Off. I think it started with an M. Something like Miracle or Muscle oven cleaner. I thought I saved a copy of the post but I can't find it.
Maybe someone will chime in with the right name.
72Sport is online now
Old 06/30/06, 05:15 PM   #3
bronco4fun1977
bronco4fun1977's Avatar
wheel it hard or stay home
Loganville, Georgia
"airplane stripper" availible at autozone. or use high quaility wire wheel on angle grinder.
bronco4fun1977 is offline
Old 06/30/06, 05:49 PM   #4
rutwad
varnish remover. I believe that's what it was. The same stuff my wife used to strip our wood furniture. Get it in gel so that is sticks to the sides better. Let it sit about 10-15 minutes, and it scrapes right of!
rutwad is offline
Old 06/30/06, 07:09 PM   #5
saryan
saryan's Avatar
Broncos are cool, but honesty is cooler.
Jenks ,Oklahoma
eBay: saryan25
I have also heard that a heat gun works......never tried it though.
No Bronco. Still laughing about the last one.
saryan is offline
Old 06/30/06, 07:36 PM   #6
tobinj
tobinj's Avatar
Do what
Martinsburg, WV
I own a spray on liner business and have found that a wood chisel is about the best, get it started under it and gently tap it and you can get it off in strips. Use MEK to clean up residue afterwards, the roll on stuff can be difficult no matter what you use but as far as my experience the chisel has been best you just have to be careful as you go. The stripper will work on it sometimes it just depends on how thick it is and well it was applied. Oh and careful on your edges they can chip fairly easy and dont use an expensive chisel as it will be worthless when you are done. Havent tried the Varnish remover but I will next time might be a little easier
tobinj is offline
Old 06/30/06, 07:53 PM   #7
YelloTx73
YelloTx73's Avatar
Katy/Galveston, TX
You can also let the MEK soften up the bedliner first, then it will scrape off, just make sure you have PLENTY of ventilation if you use MEK, its some pretty nasty stuff, but it will get the job done
YelloTx73 is offline
Old 07/01/06, 02:02 AM   #8
Blue71
Blue71's Avatar
Broncos Rule!
Johnson City, TN
Thanks for all the advise. I will let you know what I use and how it works out. Keep'em comin guys
Thanks Much,
Blue71
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'77 Wagon
Blue71 is offline
Thread Tools
Page generated in 0.26915 seconds with 56 queries
