   Ford Bronco Parts - Classic Vintage Early Bronco Parts   AutoKrafters   BC Broncos
 Bronco FAQ New
 CB Shirts + Hats
 Vendor Forum New
Free Email
Email Login
Password
Bronco Auctions
If you have any problems with the registration process or your account login, please contact contact the admin.
If you've lost your password click here.
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 09/20/06, 05:13 PM   #1
AZMike
AZMike's Avatar
Flagstaff
5.0 HO heater plumbing question
I ordered a replacement heater valve the other day and it turns out that my valve is far from a stock one. Basically, I've got a 4 port valve that will allow water to flow thru it weather or not the heater core is bypassed. I've got an 89 5.0 and was wondering if going back to the stock 2 port valve will cause any cooling issues with the motor. My gut thinking is 'No', but I thought I'd ask first.
Here is a crude diagram of the plumbing (I'm a paintbrush pro!). The red flow is with the valve off, the green is with it on. If I install the new valve, the heater hose will get no flow when I close the valve. Will this cause any cooling problems in the engine?
Thanks,
Mike
Youth may fade, but immaturity lasts a lifetime!
AZMike is offline   Reply With Quote
Old 09/20/06, 05:36 PM   #2
ransil
ransil's Avatar
Pittsburgh Pa.
I have a 2 port valve in my setup , if I close the valve the motor temperature keeps climbing, I have to keep it cracked open.
I need to install a bypass valve like the one you have.
Got an application or part number?
I tried looking thru Advance autos book but nothing was in stock.
ransil is offline   Reply With Quote
Old 09/20/06, 07:10 PM   #3
AZMike
AZMike's Avatar
Flagstaff
I found something similar for a dodge pickup in the books at Napa. Not sure of the year though.
Old 09/21/06, 08:33 PM   #4
Broncorm
Broncorm's Avatar
Perkinsville, VT
I want one of those valve??
Broncorm is offline   Reply With Quote
Old 09/22/06, 11:51 AM   #5
AZMike
AZMike's Avatar
Flagstaff
Did some more research - it loks like a 73 Ddoge Charger will work. It's not the same valve I have, but it looks like it will work with the Bronco Cable.
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2010, Jel soft Enter prises Ltd.
Copyright © 1996-2010 All rights reserved. Privacy Statement
