   Ford Bronco Parts - Classic Vintage Early Bronco Parts   AutoKrafters   BC Broncos
 Bronco FAQ New
 CB Shirts + Hats
 Vendor Forum New
Free Email
Email Login
Password
Bronco Auctions
If you have any problems with the registration process or your account login, please contact contact the admin.
If you've lost your password click here.
Go Back   ClassicBroncos.com Forums > Archives > Bronco Talk - Archives
Thread Tools
Old 12/18/06, 08:17 PM   #1
FASTERDAMITT
FASTERDAMITT's Avatar
#1 Ranked Mortgage Brokerage in the United States (Broker Magazine, June 2008
Palm Springs area
Removable window frame?
Can someone tell me what year doors had removable window frames?
FASTERDAMITT is offline
Old 12/18/06, 08:27 PM   #2
crawln68
crawln68's Avatar
EB's...some assembly may be required.
Fresno, CA
66, 67 and some 68's.
1968, 347 stroker, 100 inch WB, D60 35 spline front, Dedenbears, CTM's, Mog/9 35 spline rear, 4-link w/King coilovers, Red Neck Ram assist. 5:13 gears and ARB's F/R. 39.5 Iroks on H1 double beadlock rims. 4 wheel disc w/h-boost http://www.norcalbroncos.com
crawln68 is offline
Old 12/18/06, 09:17 PM   #3
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
66 and 67 have a unique door striker. Does not interchange with the '68 to '77 without a lot of work.
'68 is the last year of the bolt on frame and first year of the modern doors.
Early doors used a rotate inside door handle.
Late doors used the flipper paddle handle in the armrest.
Broncobowsher is offline
Old 12/18/06, 10:58 PM   #4
FASTERDAMITT
Palm Springs area
Thank's again
Old 12/19/06, 12:09 AM   #5
YelloTx73
YelloTx73's Avatar
Katy/Galveston, TX
Or you can modify the ones you have, but it probably isnt worth it unless you do it all yourself. There are three or four spot welds on each side that support the window frame. Drill those spotwelds out, weld nutserts onto the frames and attach with a hex bolt or something else that is relatively flat. Then you get removeable window frames for a fraction of what those 68 doors will set you back (depending on condition)
Just happy to still be alive.....Looking for a new rig!
YelloTx73 is offline
Old 12/19/06, 11:54 AM   #6
GRN_MEANIE
GRN_MEANIE's Avatar
BREAK IT THEN BUILD IT
HARRISONBURG, VA
Dude...my window frames are removeable!!! I had no idea. When I got my Bronco it had a couple wierd spot welds on the door but I didn't think anything of it. So if I drill these spot weld the frames are removable? Is it supposed to have bolts in it?
67' 302, C4, F/W D44 & 9", PS, PB, JD 3.5" SUSP. 2" B.L., "GOT PROPANE" DUAL FUEL KIT, Massive 33's
GRN_MEANIE is offline
Old 12/19/06, 12:15 PM   #7
Tito
Post Whore
Tito's Avatar
The life of Tito is a path of mystery on the way to enlightenment.
NoSoCenCal
I was bored a week or so ago and decided to do it, here is the link to the thread.
http://classicbroncos.com/forums/showthread.php?t=92801
Tito is offline
Old 12/19/06, 03:27 PM   #8
FASTERDAMITT
Palm Springs area
Sounds good to me.
Old 12/19/06, 07:55 PM   #9
357Bronco
357Bronco's Avatar
I'm really not a jerk...really
New Hampsha
I removed mine years ago to save weight, took the glass, tracks, regulator, and window crank out. Next, the window opening is going to be welded up and they're going on my new glass tub. Makes a super clean look, don't forget to brace the windsheild frame to the cage.
someone go back and get a shit load of dimes
357Bronco is offline
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2010, Jel soft Enter prises Ltd.
Copyright © 1996-2010 All rights reserved. Privacy Statement
