   Ford Bronco Parts - Classic Vintage Early Bronco Parts   AutoKrafters   BC Broncos
 Bronco FAQ New
 CB Shirts + Hats
 Vendor Forum New
Free Email
Email Login
Password
Bronco Auctions
If you have any problems with the registration process or your account login, please contact contact the admin.
If you've lost your password click here.
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 02/06/07, 11:33 AM   #1
method9
If Wheelin Is Wrong I Dont Want To Be Right!!!
Logan
Dead Bronco in the middle of a busy intersection!!
Please Help,
My Bronco died last night in the middle of a busy intersection. Good thing I can bench 400 lbs. and got it pushed out of their myself but it is still a problem becasue it wouldn't start after that.
I am not much of a mechanic I'll tell you what happened and hopefully you guys can help me out.
As I left work the headlights were really dim and they kept getting dimmer. Then it started to sputter as I pushed on the gas. I had a friend tow me home and I jumpstarted it and it continued to run for about 2 minutes then it petered out again. I'm thinking alternator becasue I justr replaced the battery like 6 months ago. Please let me know what your diagnosis would be.
Thanks Guys
By the way I was kidding about being able to bench 400 its more like 385!!!
method9 is offline   Reply With Quote
Old 02/06/07, 11:36 AM   #2
hillbilly delux
hillbilly delux's Avatar
Getting ready for some trails
West Point, MS
sounds like the alternator is not keeping your battery charged.
Fresh rebuild on 302 and c4, 3 inch lift, 31 inch trxus, front disc brakes...........slow progress!
hillbilly delux is offline   Reply With Quote
Old 02/06/07, 11:37 AM   #3
method9
Logan
Any Idea on how hard it is to replace an alternator?
Old 02/06/07, 11:37 AM   #4
74BroncoCO
God Forgives, Rocks Don't
Falcon, CO
Yeah, pull the alternator and have it tested at a trusted store. Maybe find a shop that will re-built it if you're on a budget. If the alt checks out, then there the wriring between it and the battery is not connecting. I have a similar issue with mine.
J.D.
1973 Bronco 351 SEFI, 5.5" lift, ZF 5sp, Atlas 4spd, Roll cage, 35" MTR's on Champion Beadlocks, Discs...
Give Jesus a chance, He died for the opportunity. www.ucora.org
74BroncoCO is offline   Reply With Quote
Old 02/06/07, 11:38 AM   #5
jdevon
jdevon's Avatar
All I need is more time and more money...
Dallas Area
i second the alternator. you might check the cables as well as the connections btwn the battery and alternator. if you need a new alternator, contact rrraaayyy2 on this site -- his alternators are fantastic.
1975 Ranger
jdevon is offline   Reply With Quote
Old 02/06/07, 11:38 AM   #6
74BroncoCO
Falcon, CO
Pulling the Alt is EASY. Probably just two bolts.
J.D.
Old 02/06/07, 11:41 AM   #7
hillbilly delux
West Point, MS
dude if you dont have a chilton or hanes manual for your bronco.....you need to get one. It will show you how to replace ALMOST anything on it.
Old 02/06/07, 11:42 AM   #8
daddyg
Bronco Parts Collector
daddyg's Avatar
Bronco Master Wannabe
Harvest, AL
I will second the alternator theory. Check the connections for the Alternator. Several years ago I had a connection on the back of my alternator come loose and it did exactly like your describing.
74 - Trail rig owned for 26 years
76 - Street / Trails
73 Explorer - All stock
daddyg is offline   Reply With Quote
Old 02/06/07, 11:51 AM   #9
Skuzzlebutt
PhD, Dr. of Broncology
Skuzzlebutt's Avatar
I am Skuzzlebutt, Lord of the Mountain!
Honeymoon Bay
It could be the regulator has gone bad. Those are much cheaper and easier to replace. But 9 times outta 10 it's a bad alt that causes your symptoms.
Chris from Whidbey Island
I've got a lovely bunch of coconuts.
Skuzzlebutt is offline   Reply With Quote
Old 02/06/07, 12:03 PM   #10
method9
Logan
Do you guys know why Bronco's are worth so much? 2 of many reasons;
1) They look bad a$$ and are bad a$$.
2) 24/7 you can get guys like you all to help out with any questions or concerns you may have.
Thanks for the quick replies I know what I have to do now.
I appreciate it
Old 02/06/07, 01:11 PM   #11
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Try getting the battery fully charged then run it down to the local parts store and have them test your charging system they can tell you if its the alt, reg, or battery. I also vote for the alt being bad.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline   Reply With Quote
Old 02/06/07, 01:18 PM   #12
Apogee
Apogee's Avatar
Cuz that's how I roll.
Tangent, OR
My first guess would be alternator as well, however I had a brand new battery do the almsot exact same thing to me once (except it was in the middle of a bridge, not an intersection) and it ended up being the battery. One of the cells died...end of story.
I'd take the battery, alternator, and voltage regulator in for testing.
"It's what I does."
Apogee is offline   Reply With Quote
Old 02/06/07, 01:32 PM   #13
bannind
bannind's Avatar
Boise, ID
And if they tell you the alt is bad, don't just buy a new one from the store..
Either contact Rayyyyyyyyyy for one of his setups or do a 3g from a junkyard. If you spend money on a stock alternator when you could do the 3g for less, you will kick yourself.
Perfect upgrade opportunity.
bannind is offline   Reply With Quote
Old 02/06/07, 02:10 PM   #14
method9
Logan
What is the 3G?
Old 02/06/07, 02:27 PM   #15
bannind
bannind's Avatar
Boise, ID
3G alternator... 3rd generation. There are lots of different options you can go with from mild to wild.
Without a doubt the easiest would be too call up Rayy.. But it is more $$ than doing it yourself. Rayyyy is a great guy to work with and will tell you everything you will ever want to know about alternators. There are various levels of drop in or ease of use donors. Just run a search on the boards for alternator upgrade and you will see a whole new world. The donor list is long and it cleans up alot of wiring as the 3G is internally regulated. It will however take away your Alt Meter or idiot light, but it is a small price to pay. 130 AMPs is great and is a perfect begining upgrade to start with.
This thread is one of the many with a donor list in it. http://classicbroncos.com/forums/sho...rnator+upgrade
I ended up picking up 2 3G alts for 5$ at the junkyard today so they shouldn't cost you much.
Good luck and remember there are always people here willing to help.
dan
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2010, Jel soft Enter prises Ltd.
Copyright © 1996-2010 All rights reserved. Privacy Statement
