broncoluv
I just pulled a 5.8 with c-6 out of a 95 crew cab today that met a bad driver recently, got the whole thing for $650.00 if you can beleive that. The guy just wanted it out of his yard! So i did some investigating and have found i need the advance adapter to run my dana 20, i need a harness, but ryan sounds scary, although i did pull the entire harness and eec from the donor it doesn't look to fun to try and reuse, efi pump, return fuel line,( how do you run the return line into the tank?) new drive shafts, and a new hood(maybe just leave it off!) Everyone seems to run the 5.0 with the mustang efi, i hope i can make the stock stuff work with a custom harness. I'm looking for driveability and don't plan on engine mods any time soon. Any help, direction to info, or prayers for a successful swap would be greatly appreciated, especially in the wiring department. Thanks, ive learned a lot from you guys.
