   Ford Bronco Parts - Classic Vintage Early Bronco Parts   AutoKrafters   BC Broncos
 Bronco FAQ New
 CB Shirts + Hats
 Vendor Forum New
Free Email
Email Login
Password
Bronco Auctions
If you have any problems with the registration process or your account login, please contact contact the admin.
If you've lost your password click here.
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 04/12/07, 06:50 PM   #1
Dan_W
Newbie
Upper Falls, MD
eBay: 7603chap
Front disc conversion question
I am going to install a front disc conversion on my 71 with a Dana 44. I am most likely going to use the kit from Horsepawer111 on ebay. Is anyone running 15" rims with a disc kit? I want to run 15" aluminum rims with this kit and I want to make sure they fit before I order them. I am concerned with the inside diameter. They have good backspacing, around 3.5". Any help or suggestions is appreciated. Thanks
Dan_W is offline   Reply With Quote
Old 04/12/07, 07:02 PM   #2
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
The kit you describe is the standard GM disk brake conversion. Your 15" wheel will fit. 99.99% of the time there is no problem.
Broncobowsher is offline   Reply With Quote
Old 04/12/07, 07:04 PM   #3
cactushorse
75 Stroppe
Marana,Az
I'll second that.
cactushorse is offline   Reply With Quote
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2010, Jel soft Enter prises Ltd.
Copyright © 1996-2010 All rights reserved. Privacy Statement
