Thread Tools
Old 03/02/19, 02:47 PM   #16
UTbronco
Weber/Davis Counties
Originally Posted by JLBachs View Post
Any chance you could have a plugged fuel strainer in the tank causing the pump to work as hard as it possibly can?
Hmmm, maybe I guess. We'll check it out -- thanks for the idea.
UTbronco is offline   Reply With Quote
Old 03/02/19, 06:22 PM   #17
Skiddy
Skiddy's Avatar
Lookin at yer booger welds
Shawnee, OK
Originally Posted by UTbronco View Post
Yes, definitely hear the pump run for a few seconds then stop just prior to cranking the starter. I don't believe we have a fuel return going from the fuel pressure regulator so that's something we'll take a look at. Thanks for the response!
yeah if you don't have a return it will burn up the pump
Tried True Ford Blue RIP my brother Mstark
74 Bronco with Mustang 5.0 EFI w/painless harness, C4, 4.56 gears, D20 twin stick, 35's, 3 1/2" SL, long arms, 3" BL, rear spool, Grizzly front locker D44, full cage, 5pt harness. bla bla
Skiddy is offline   Reply With Quote
Old 03/03/19, 08:21 AM   #18
BGBronco
BGBronco's Avatar
Nashvile
I have a crate motor and then went to EFI. I had this long running issue of the engine dying. It was never consistent and a real pain. Before I did the EFI, I swapped out the mechanical fuel pump, voltage regulator, and ignition coil trying to solve the problem. Same issue. I did the EFI conversion a few months ago. Same issue. It turned out to be a bad ignition control module. As soon as I started to unplug it, the connectors basically fell about. $25 part that should have been replaced a long time ago.
76. Crate 302. FiTech. C4. 33x12.5x15. PS. PDB. 1.5" WH Lift. KrawlersEdge Cage.
BGBronco is offline   Reply With Quote
Old 03/03/19, 10:48 AM   #19
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
An EFI fuel pump without a return is a dead headed fuel pump. You are probably warming up on 90 PSI of fuel pressure. Warmed up the fuel pump is probably overheated from running overloaded.
Bad ignition typically shows up hot as well. Without an ignition signal the fuel pump won't run except for the initial prime.
So much sounds like it could be a problem. I wouldn't be surprised if you have multiple fixes to get things right.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
Why do people keep expecting "normal" from me?
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is online now   Reply With Quote
Old 03/07/19, 03:54 PM   #20
UTbronco
Oh dang! Well shoot, I'll add this to the list to check too. I'm tired of not being able to drive in the summer for more than just a few mins at a time.
Old 03/07/19, 03:55 PM   #21
UTbronco
Yeah, definitely going to look into the return and the ignition as a starting point. Hopefully it's an 'easy' find.
Old 03/08/19, 08:16 AM   #22
Cooter_76
Cooter_76's Avatar
Austin, TX
Originally Posted by needsmoarturbo View Post
Another thing to check would be the tfi ignition module thing that is mounted to the distributor base. Those will crap out when hot.
This. Had the same problem with an '89 F-150. Kept thinking it was the fuel pump, but it was that damn module. Good luck!
73 - Soon-to-be Explorer 5.0/4R70W, 2.5" suspension lift, 1" body lift, 32" BFG KM2's, Ch*vy disc brakes, twin sticks, Rampage Soft Top.
Cooter_76 is offline   Reply With Quote
Old 03/08/19, 02:03 PM   #23
ransil
ransil's Avatar
western Pa.
Pull codes
Sent from my SM-G920V using Tapatalk
ransil is offline   Reply With Quote
Tags
efi, fuel pump, mustang computer
Thread Tools
Page generated in 0.41565 seconds with 61 queries
