Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 11/13/19, 10:07 PM   #16
nickgp
las vegas. nevada
I’m using the Art Carr/Winters gate shifter. It’s cable operated so binding is not an issue. You always know what gear your in. It’s great for function however it may not be everyone’s style.
nickgp is offline   Reply With Quote
Old 11/13/19, 10:21 PM   #17
nvrstuk
nvrstuk's Avatar
20 gears forward...no reverse!
WA
Where did you find the shifter? Nobody has one available...? at least with my search skills??
Strrroker powered...460 SBF cubes, dyno'd:597 HP, 710ft lbs, SEFI, EDIS, 20+ fwd gears...CB build:http://classicbroncos.com/forums/sho...d.php?t=278607NWCBStroker/SEFI/EDIS/4r70W/KluneV/TrueHi9 build http://northwestclassicbroncos.com/s...n-to-SEFI-EDIS
nvrstuk is offline   Reply With Quote
Old 11/13/19, 10:36 PM   #18
garberz
Bronco User
garberz's Avatar
Clear me a path...
Conejo Valley, Ca.
Originally Posted by nickgp View Post
Iím using the Art Carr/Winters gate shifter. Itís cable operated so binding is not an issue. You always know what gear your in. Itís great for function however it may not be everyoneís style.
This is my style, itís the best floor shifter!
Mark
EFI, OBDII, 5.0, C4, AtlasII 3.8. 5.13ís, HP44, Detroit's, 37ís, Duff Long Arms.
garberz is offline   Reply With Quote
Old 11/13/19, 11:06 PM   #19
nvrstuk
nvrstuk's Avatar
WA
Yeah, I use the Winters shifter also. Over 9 years now.
I use it so much I wore half way thru the shifter "shaft" on mine years ago so it was warranted and I received a hardened hollow shaft so I can run a micro switch in the knob.
Sorry- reread your post and it clearly states stock look.. Go with a column shift.
Old 11/14/19, 01:37 PM   #20
rafitz24
Newbie
Winters was my first choice but was unable to find anyone that had it available anymore.
Sent from my SM-N960U1 using Tapatalk
rafitz24 is offline   Reply With Quote
Old 11/14/19, 04:46 PM   #21
72_EB
66to77
72_EB's Avatar
I'll agree with the others that a Winters or Art Carr is one of the best, but he did say he wanted to stick with a stock look and they are definitely not that.
You can wack you leg on the shift lever on a stock setup wheeling. Kind of annoying. This is where a reverse pattern Winters or Art Carr on the floor is nice.
Yes, you'll be cursing the B&M ratchet and they look pretty ugly too.
Never tried a Lokar, but always wanted to. I think they look pretty, but I think it involves a bit of fabbing to make work.
I have an early Mustang floor shifter, I always wanted to try with a cable, but never messed with it. Let me know if you want the challenge. I'll dig it out for shipping $. You can try it.
72_EB is offline   Reply With Quote
Old 11/14/19, 05:42 PM   #22
Rustytruck
Rustytruck's Avatar
honest the bolder ran under me
El Monte CA
Originally Posted by SteveL View Post
Have you tested this set up?
No but that is what I would do. would re leave the twist that binds the linkage up. column going with the body and the tranny going with the frame.
1974, stock 302, C4, BFG KM2 33x12.5x15, 8in rim, detroit rear, trutrac front 4.11 gearing, Warflairs,2.5" lift, chevy disc conversion, Hydraboost, owned since Christmas Eve 1977
Rustytruck is offline   Reply With Quote
Old 11/14/19, 07:15 PM   #23
scuba76
Newbie
Omaha
Art Carr/Winters gate shifter only way to go
Sent from my Pixel 2 using Tapatalk
scuba76 is offline   Reply With Quote
Old 11/14/19, 10:20 PM   #24
68ford
68ford's Avatar
mission viejo, ca
I get the reverse lock out being a little bit of a pain, but I have had a bnm mega shifter for about 40k miles and a ton of fast shifting in race environments. I have not had a single issue. Mine is mounted to my cage and I'm not using the plastic cover. It is also full of dust from countless hours of following right in people's dust.
What are the issues people have with the rachet type shifters? My actual race truck has a Winters in it. Both have pluses and minuses in racing applications.
68ford is offline   Reply With Quote
Old 11/19/19, 05:28 AM   #25
jerrybromley
Newbie
jerrybromley's Avatar
I think I can....I think I can...I think I need more parts ;-)
Ludington MI
Wow THANKS for all the feedback. One of our fellow Classic-Bronco guys came up with a stock column for an automatic so I bought it from him. After some thought about what looks cool and what would be more fun to drive I realized the floor shifter would just be another thing on a very small floor to get in the way
jerrybromley is offline   Reply With Quote
Old 11/19/19, 05:32 AM   #26
jerrybromley
Newbie
Ludington MI
Another thought occurred to me, I am planning a 1 inch body lift. Has anyone had problems with the shifter rod length with a body lift
Old 11/19/19, 07:36 AM   #27
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
Should be enough in the adjuster for that.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
Why do people keep expecting "normal" from me?
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is online now   Reply With Quote
Old 11/20/19, 09:07 AM   #28
abn373
abn373's Avatar
Charleston, SC
Winters is now making them under a different division of their company called Maverick Performance and apparently can be ordered direct. Here is their catalog link if that helps.
http://www.maverickperformance.com/
I have a different gate on mine that makes it easy to go back and forth from R to D so if I would need to I can have it over to the side and go back and forth, but if its on the other side of D (3) I don't have to worry about coming from 2nd to 3rd and going through N to Rev.
'73 Bronco. Fiberglass tub, 302/C4, 3" Suspension lift w/ 35x12.50 15 Cooper SST
abn373 is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright © 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.34496 seconds with 63 queries
