Thread Tools
Old 10/12/19, 01:18 PM   #1
mattbyrne
Aurora, Il
Painless Wire Harness Qustions
I'm in the process of installing a Painless Wire Harness in my Bronco. I have updated by alternator to the 3G one wire from Wild Horses and replaced amp meter with voltmeter. There is a voltage regulator located on the back of the gauge cluster, do I need this anymore? I thought the voltmeter for the original alternator was on the fire wire? If it's not a voltage reg what is it?
Now that I have replaced the amp meter with voltmeter should I remove the unused wires in the painless loom or just leave them there?
mattbyrne is offline   Reply With Quote
Old 10/12/19, 02:38 PM   #2
904Bronco
904Bronco's Avatar
So many Ford's, so little time...
Morgan Hill, CA
On the back of the cluster > Yes it is needed, reduces voltage to 5v so the gauges will work properly. So 12v Key in run position only power to plus (+) side of it and then (-) to gauges.
Unused wires? One thought - leave them so that they might be repurposed later once the harness has been loomed up.
1967 Poppy Red U15 Lubr... soon to be 96 Explorer EDIS and NV3550
1971 Grabber Green U15 Lubr... 2000 Explorer EDIS and 4R70W
2016 Shelby GT350 - Race red
2002 F250 Superduty 7.3 207K and still going!
1996 Saleen Mustang 130K... Project car (SOLD)
2001 Bullit Mustang. Son drives this one
904Bronco is offline   Reply With Quote
Old 10/12/19, 02:50 PM   #3
DirtDonk's Avatar
San Jose, CA
What 904 said. These are two separate voltage regulators we're talking about.
The old voltage regulator under the hood for the charging system is no longer used, but the voltage regulator for the instruments is still very much needed for the Temperature and Pressure and Fuel gauges. It was never used for the ammeter anyway, so nothing you've done changes it's use.
It's also called a "constant voltage supply" or an "instrument voltage regulator" or "IVR" for short.
The big Black w/yellow wire that would normally have gone through the ammeter loop is an absolute must-have wire, so you don't do anything with that other than leave it connected to itself and tucked safely away under the dash. Just because it no longer works with the ammeter does not mean that all of it's other functions are no longer needed.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is offline   Reply With Quote
Tags
painless, voltmeter, wireharness
Thread Tools
Page generated in 0.40404 seconds with 64 queries
