Benny
LOCAL PICK UP ONLY ------ LOCAL PICK UP ONLY
First come First serve
I have a James Duff Suspension system that was partially installed on my Bronco before I bought it. I believe this is the system https://www.dufftuff.com/System_G_3_5_Ultimate_Suspension_Lift_Bronco_p/5000g.htm
I believe that it wasn't driven much after it was installed. (None by me anyway) But it did sit outside for a while hence the dirt and rust. It is missing a few pieces that I know of U-Bolts, rear shock mounts, front shock mount tabs and a few poly bushings (the old bushings are pretty ratty though).
I need this corner of the garage back and am hoping that someone can use these. I will be around through Wed 10th but I they are still around by the weekend I could possibly leave them on the porch.
PM me for the address.
Ben
Ben
