Moving soon and not taking everything!
Added 12-3
Accelerator pedal $5
Scott Drake Stainless Door Strap Kit $20
Wild Horses Door Hinge Rebuild Kit $20
Kiser Riser Pics added below
Update 12-2 - Please PM me if you want something or I will most likely miss it!
Vintage air parts pics added
Adding:
WH 4.5 Rock Cralwer Coils - Black - Excellent shape $100
OEM Trac Bar with good bushings $45
Sold: Heads and cam include Timing chain set and lifters as well!
Original Post:
Sold: Complete Explorer Serpentine setup with harmonic balance and crank pulley, tensioner, alternator and bracket, remote reservoir power steering and bracket, A/C compressor, clutch fan, belt. $300
Sold: Custom Chrome/white gauge cluster by ClassyChassis - $300
Holley Truck avenger 670 (electric choke), Misc Holley carb parts/spares $300
OEM 289 cast iron exhaust manifolds (pair) The PN's of the manifolds are D10E-9430-CB and D1AE-9431-BB $75
Sold OEM bronco 289 oil pan with Lokar flexible dipstick $75
OEM 28oz flywheel, starter, LUK clutch assembly $100
Sold: Wild Horses V8 fan shroud, steel, black - used with explorer clutch fan and 1" body lift. Slightly trimmed the ring for clearance. $35
Sold: Ford GT40P head swap with 15k miles on the rebuild. Includes heads and Comp cams SK31-216-2 S Kit and push rods. $150
Sold: Fiberglass Hood Scoop. Bolt on, will cover 18-19" hole. Black $45
Weld On Trac Bar Riser (Kiser Riser), used $25
Driver Air Duct Inlet Seal (Square) NIB $5
7" Pitman arm (straight, not drop) OE - $50
Sold: Used TBP Poly Fender flares $40
VIAIR 91050 Air Tank, NIB (used for mock up only - never filled), 5 gallon $50
Fuel Pressure Regulator, low pressure for Carb, non-return (dead head). Single inlet dual outle p/n 15952 $30
Original body side trim (no spare tire) $200
Bunch (?) of a BCB vintage a/c kit. Used and removed, let me know if you are looking for parts - N0T COMPLETE
York 209 Air Compressor for OBA - $125
Set of 15" aluminum rollers with ok BFG's $150
and more?
Added 12-3
Adding:
Original Post:
and more?
