Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 03/16/19, 06:43 PM   #1
bronconut73
bronconut73's Avatar
How did you do that?
Orlando
Duff Rocker Guards
Finally installed my Duff Rocker Guards.
I got the ones with tube step to keep big stumps off of my doors.
No real rocks in Florida....but lots of big, hidden stumps that will take out a rocker.
Love me some Duff's
Click image for larger version
ID:	473561   Click image for larger version
'73, 3.5" sl, XL RS9's, F-250 mounts, Duff long arms, 1" bl, 35" MTZ's, C-4, twin sticked, P.S., built 351W, Exp Serp, F&R Detroits, 4.11's, chromo axles, 11 leaf packs, SuperJoints, Chevy front disc, BC rear disc, BC Vintage a/c, Scat Procar 2K seats, Alpine/Pioneer, Bear, Cobra 148 GTL/Texas Star.
bronconut73 is offline   Reply With Quote
Old 03/16/19, 06:44 PM   #2
bronconut73
Orlando
Next is the SRE Stonecrusher Steering system and Torque Tamer from Duffs.
Old 03/16/19, 06:49 PM   #3
hyghlndr
Delaware ????
Looks great have a set I need to install, so much to do and so little time.
hyghlndr is online now   Reply With Quote
Old 03/16/19, 07:03 PM   #4
txtruk15
txtruk15's Avatar
50 years of EB love, 3 years of EB ownership
Highland Village, TX
I need to get that torque tamer, thanks for reminding me about spending more money....
' _____
|_____|
'70 Wagon, '87 5.0L, 37x17s, Dana 44 & 9",
(o===o) NP435, D20, lockers, 4.56 gears, Icons,
||---o-|| Logans bumpers, mastercraft, superwinch
txtruk15 is offline   Reply With Quote
Old 03/16/19, 07:16 PM   #5
BGBronco
BGBronco's Avatar
BG, KY
Here are mine.
76. Crate 302. FiTech. C4. 33x12.5x15. PS. PDB. 1.5" WH Lift. KrawlersEdge Cage.
BGBronco is offline   Reply With Quote
Old 03/16/19, 07:18 PM   #6
Bronco Junkie
So Cal Broncos
Bronco Junkie's Avatar
Los Angeles
Lookin' good! I got 'em on mine as well.
"Life is tough, but it's tougher if you're stupid."
"Don't piss down my back and tell me it's raining."
"When I started using dynamite I believed in many things....Now, I believe only in dynamite."
Bronco Junkie is offline   Reply With Quote
Old 03/16/19, 08:49 PM   #7
abn373
abn373's Avatar
Charleston, SC
Want to put those on, but cant seem to get an answer if they will work with a Kentrol fiberglass tub. Even called Duffs and no luck with an answer.
abn373 is online now   Reply With Quote
Old 03/16/19, 09:09 PM   #8
bronconut73
Orlando
I had to bust this into two separate weekends.....but it could be done in an afternoon.
The problem is after you massage your old and tweaked rocker and drill holes in your sheet metal you need to prime and paint to protect from future rust so .....ya know ....it snowballs...lol
Having said that.....it is another great part from Duff's that could be installed in an afternoon if I had my stuff together and didn't want to tweak and fix and paint everything as I went....
Bronco life
Old 03/16/19, 11:12 PM   #9
Hultzger
Martinez
Those do look good.
Does anyone think they'll work on mine or have a suggestion for something? The PO cut out the rockers.
Hultzger is offline   Reply With Quote
Old 03/17/19, 08:30 AM   #10
bronconut73
Orlando
These mount to the rockers so they may not work for you.
Some fellas here on cb have taken a piece of square tube steel. They weld that into the body.
It may sound clunky but these guys make it look good and it is uber strong.
Some make it look just like the stock rocker "at a glance" ....
others take something like a 2"x6" steel tube and weld that in place of the rocker. It provides more clearance and sticks out past the body a bit. It's a good look.
Old 03/17/19, 04:28 PM   #11
74fiberglass
barnesville Pa
I was wondering how they would hold up on a fiberglass tub also.
74fiberglass is offline   Reply With Quote
Old 03/17/19, 05:04 PM   #12
bronconut73
Orlando
I would want Mike or Susie at Duff's to answer that question.
It seems like that it would dramatically reinforce that area of the tub and would be a good thing. But I'm just not sure. You may be a candidate for the rocker guards that bolt or weld to the frame
Old 03/17/19, 05:39 PM   #13
Hultzger
Martinez
That sounds like a good fix. I'll have to search for some photos. Thanks!
Old 03/17/19, 08:47 PM   #14
abn373
abn373's Avatar
Charleston, SC
I was thinking they may help protect in a t-bone on the street with my FG tub is why I wanted them. Cars would hit both wheels/tires but there is always some under-ride that may cause a push up into that area. Some steel rockers would help for sure. Plus they look cool.
Old 03/18/19, 09:48 AM   #15
Crush
Crush's Avatar
"It's better to be dead and cool, than alive and uncool."
Greenbottom, WV
eBay: 5.8Bronco
ok. I have the NON-step version from duffs and they mount with several riv-nuts along the top/center but the end attaching points are bolted through the rear quarter and the front fender. so those two areas can get a large washer/piece of plate put behind it for support. also if your front fender is steel that will help too. for the other bolts, I would not use the riv nut in FG in that area for fear of pulling out of the glass. I dont know how the back side of that tub looks but I would look at opening up the back side so you can get a long threaded plate in there or maybe drill holes all the way through so you can put sleeves in each hole and a long plate on the back side to be able to mount it all snugly
76 Special Decore options are undecided it is a bare canvas. 77 Explorer with Special Decore Group, 5.8,M5OD 5 speed, 3.5" rancho lift and 1" wild horses body lift, cut fenders, original 15x36x15 Dick Cepek Fun Country tires and custom early 80's interior.
Crush is offline   Reply With Quote
Page generated in 0.39970 seconds with 63 queries
