- Oct 14, 2004
- 5,001
Now that both of my Broncos are fuel injected I don't need all the carburetor stuff under my feet. Listing them a little early to see if there is any interest, will take pics and add to this post this weekend with prices.
1 - Holley 670 TA - This carburetor was sent back to Holley to confirm it didn't have any of the problems common for some of the truck avengers. Ran it on my 395 stroker for 8 years. Included with it will be a Holley Jet kit ($50 value), extra power valve and squirter nozzle from where adjustments were made.
2 - Rock Auto, Autoline, Autolite 2V remanufactured Carburetor, it's about a year old, installed and run in the driveway but wasn't happy with the idle and didn't have time to work with it before heading to an event so I swapped it out with another Carb. I'm sure it can be adjusted by somebody that knows what they are doing and will be fine.
3 - ***SOLD*** UREMCO - Autolite 2V remanufactured Carburetor - Still in the plastic and in the original box. Had planned to put this on permanent in place of the Holley 2V but decided to go EFI instead.
4 - ***SOLD*** Holley 350 cfm 2V - Purchased at Summit to make the Super Summit Event in June of this year, planned to replace with the unopened Autolite but never did, Ran it a couple days at OCBR and just pulled it off, basically brand new. Has 6an fitting. Included will be a Carter 4070 pump complete with bracket and 6an fittings, also included is a fuel pressure switch and gauge with 6an fittings. And also a Holley filter with 6an fittings that you can change the filter screen.
5 - Old Carter 4V - would need rebuild kit but did run when I pulled it off.
***SOLD*** Carter 4070 electric pump that I carried for a spare, I ran it for about a year and replaced with a new one(listed with Holley 2V) when I started carrying a spare, it's like new and just like it came in the box with regular hose fittings except it is missing the mounting bracket.
