Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 12/30/20, 11:33 AM   #1
Cactus killer
Cactus killer's Avatar
Just because it works dosn't make it right Jason BC Broncos
BC Broncos REAREND kit is officially available
We have been working with wilwood on the brake kit part for a while, we got it a few months back and finally got it all installed and tested any it is awesome.
The kit is 100% NEW rated at 1300 hp complete with everything you need.
https://bcbroncos.com/shop/engine/co...t-bc-standard/
We have quite a few options from axles only, complete without 3rd member
Different brake options, to the ultimate one posted here with electric emergency brakes ( that means no pedal in the cab, cables, brackets or holes in the floor to deal with.
The axles, axle housing, brakes, pinion support and strange case are all made in the USA.
Here is to official info
This Rear axle kit includes: Black Wilwood brakes with electric ebrake caliper, 2 US MADE 35 spline HD, Big Bearing Moser axles, 2 sealed bearings pre-installed, 2 housing seals, retainers, HD 2 spring perches, 2 Shock mounts and US MADE HD housing with 3.25″ tubes. The 3rd member is a 100% new Strange nodular case with 456 gears, 35 spline Detroit locker, Daytona pinion support and 1350 yoke. The kit also comes with SS drop line, hardlines, SS caliper lines brakeline tabs, clips Lublocker gasket and hardware. The shock mounts and spring perches will need to be welded to the housing once you have installed it, so you can set your pinion angle correctly for your lift. Ships in aprox. 3 business days.
We created a standard size, length bearing type and offset that we have been using since 2003 that works great. One really great thing about this is if you ever need a replacement axle or bearing we will know your measurements bearing size and offset, we generally keep replacements in stock so down time is at a minimum.
Click image for larger version
ID:	514949   Click image for larger version
Jason BC Broncos
Cactus killer is offline   Reply With Quote
Tags
bc broncos, electric emergency brake, rear end, rearend, wilwood
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.44677 seconds with 70 queries
