    Discuss it more here:
CA Ca
AndoAlto
open
Multi point fuel injected out of an '89 Crown Vic 302 and rail mounted eletronic fuel pump with in-line filter.
C4 transmission out of a 73 bronco with forced air cooled mounted on the the inner fender well.
B&M Megashifter ratchet style lock-out shifter.
Dana 20 transfer case with twin stick modification. Front axel detent retained so it doesnt allow for front axel only capability.
Dana 44 front axel from a 74 bronco with 32 sline axels, detroit locker and 4.56 gears
Rear is a small bearing 9in with 31 spline axels, detroit locker and 4.56 gears from a 1972 bronco.
First gen bronco heavy duty power steering conversion kit for rock crawling, with f-350 gearbox.
Tie rod over kit to raise the tie rod for clearance, made out of DOM tubing with Chevy 1 ton tie rod ends.
90A alternator
9000lb winch
Tom Woody extended rear drive line
5 in lift from Tom's Bronco Parts
2 inch body lift
2x7 reinforced steel rock skis under each door
Best Top soft top with fiberglass door inserts
Herculiner in tub
Spare tire carrier swings on a 1/2 ton bearing so it can be tightened without having the carrier drop when opened
A
AndoAlto
Is it worth it?
If not, how much?
Lookinf forward to your comments
A
AndoAlto
Didn't catch it in time before the post was removed to get more of the pics. That's the only one I saved. But, what do you think about the bones? As my title says, I'm a "newbie"
A
AndoAlto
I’m going to see it and wanted some input before I do so, so that I could ask the right questions and look for anything you all suggest.
JGO
It's a wheeler and seems like it was built many years ago. It's probably going to be a little raspy and require some work. It's resale value goes down when the body is cut for the trail like that. If you like it, buy it! You are in great negotiating position on a Bronco like that because there are less people targeting them IMO. Hope this helps! Jim
A
AndoAlto
Thanks a bunch, Jim. That does help a lot and is much appreciated.
A
AndoAlto
Is there something that is considered by the general consensus on the forum to be "a happy medium" between a 4.56 set up and one that is of a lesser ratio? So that it could be used as a daily driver and one that can also be used on the trail (albeit maybe not as super imposing of a trail)?
I'm thinking whether i'd have to change the 4.56 so that I can take it out on the highway comfortably...as I type this, I feel my "newb-ness" trust me...and would you suggest any other changes in the bones listed above to make it more of a daily but also remain some of its monsterous character?
I'm just trying to figure costs in "making it mine" as they say.
JGO
I don't enjoy driving them until they are done. To me "done" means modernized with overdrive drivetrain of some type and good brakes. I usually install Explorer drivetrains that gets you fuel injection and a 4 speed automatic. Cost will add up no matter what so you might as well build something nice that will be worth a lot. I have a 69 for sale for $20k that with another $10k put in will be worth $60k or so if you turn your own wrenches.
sprdv1
REBEL
Don't blame ya....
