Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 08/05/20, 11:58 AM   #1
badshoe
Prince George
eBay: badshoe
BadShoe's AODE/4R70W air test plate
Introducing BadShoe’s Ford AODE/4R70W air test plate. This tool is used to verify clutch, band, and accumulator activation on the AODE/4R70W-75E family once the tranny is assembled. The kit comes with an 8x13- ¼” 6061 alloy test plate, twenty-one stainless steel hold down bolts, two line-up studs, gasket and instructions. I have added a “peep” hole in the plate so the OD band application can be observed. By using this tool, you can verify the integrity of the piston seals and slip rings. This will give you peace of mind before bolting in the valve body and finishing the build. Email me if you have questions or check my web site for details.
www.badshoeproductions.com
BadShoe Productions, How To instructional videos specializing in Ford Drivetrains
badshoe is offline   Reply With Quote
Tags
4r70w, air test plate, aode, badshoe
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright © 1996-2020 All rights reserved. Privacy Statement
Page generated in 0.44982 seconds with 69 queries
