71 Cali Bronco Build
71 CA Bronco
71 CA Bronco
Off to the exhaust shop this morning. I take the rainbow as a good sign. :)
71 CA Bronco
71 CA Bronco
Exhaust is done. :)
71 CA Bronco
71 CA Bronco
Very clean.
How does it sound?
It hasn't been fired up yet. Waiting on dash to come back from the painter so I can finish the wiring. Then we will be ready to fire. Its getting really close. Can't wait....;D
71 CA Bronco
71 CA Bronco
Heater switch and bracket install.
71 CA Bronco
71 CA Bronco
Getting Lokar linkage and Dakota gear selector indicator set up. Had to make another bracket to hold the Dakota digital indicator sender. The ones supplied with the kit are a bit of a mess. If you go this route make sure you get the right Lokar linkage. It has to be specific to the 4R70W trans. I have an extra one for the C-4, now if someone is in need?
71 CA Bronco
71 CA Bronco
Wild Horses Wiper setup is done. I think it turned out really nice.
71 CA Bronco
71 CA Bronco
Trying to figure out a way to cram my overflow tank next to the radiator. If you have any ideas feel free to chime in. I wish the Ron Davis overflow outlet came out the back instead of the side. Its really tight with the battery re-located to the driver side. The overflow tank came with a really nice bracket but will not fit. Too wide. I will most likely try a modified band clamp of some sort.
71 CA Bronco
71 CA Bronco
Started on the dash and glove box. Plus more wiring.
71 CA Bronco
71 CA Bronco
Glove box.
toddz69
Looking good! Just came here recently upon the recommendation of ntsqd. Do you have any close-up pics of your p/s reservoir?
Thanks,
Todd Z.
71 CA Bronco
71 CA Bronco
This is what I have. Lee PS tank and Lee modified explorer pump. I'm hoping it will clear the hood. I have not tried it yet. :)
toddz69
Thanks for the additional pics - looks very similar to the one that Tom did for me years ago although yours had returns at a different spot that allow fitment of the a/c compressor. I'm not sure mine would fit. I like my modified Explorer pump that they did for me too.
I have a 2" body lift and Highlander hood and it clears ok but I think it does sit lower than yours.
Todd Z.
71 CA Bronco
71 CA Bronco
Picked up a set of nice front seats today. Got the idea from Remos here on the board. They are out of a 2005 BMW 330Ci.
71 CA Bronco
71 CA Bronco
They are electric plus seat warmers. Now I just need to figure out how to wire them.
71 CA Bronco
71 CA Bronco
I finally got the overflow tank squeezed in there. I made a bracket that mounts to my battery box. Seems to work well with the limited space.
71 CA Bronco
71 CA Bronco
Front clip is installed.
