Good point with roll cage clearance. We also should mention using a track system that bolts to the bed rails (existing hard top bolt holes) and velcro attachment to the rear tail gate similar to Kayline/Rampage style.
As mentioned earlier >> Removable clear windows are desired. I would purchase a set of tinted windows if offered as well.
I would absolutely advise them to use the existing holes for the hard top like the others offer. The rear however (and if you look very closely at the late model blazer, I’ll try and attach a pic) has a rod that goes across the lower part of the window and clips into the rails. This eliminates any need for a track to be screwed to the tailgate or Velcro to be used unless you’d like to add an extra stick to it. It will also allow you to lower the tailgate without undoing the rear window (I love this accessibility)
Based on their other offerings and style, I do not know if they would provide a zip-out window for these. All of their other tops use a roll up “safari” style look of the old STC and Kayline tops. I can inquire about ordering a top with either tinted or clear, but zip out may be an entirely other thing.
I do see on their site an offer for a “mesh screen panel” that can be interchanged for the rear window as well that may be an option for us.
