joeracer69
- Feb 24, 2009
- 50
Restomod build, on a 39,000 original mile 1973 Ranger model Bronco.
Original 302 V8 block was rebuilt for performance and adding the reliability of modern EFI. All hiding under the stock Bronco air cleaner.
Motor is rated at 350hp.
A lot of effort was put into the engine bay to make it look stock. Such as hiding the modern wiring.
New gas tanks. Rear is 23gal.
Fresh C4 automatic trans and Dana 20 twin stick transfer case.
Very highend suspension system with Bilstein remote reservoir shocks, rear swaybar and limiting straps.
The ride and handling of this Bronco is simply amazing.
True-track 9" rear all new. (4.10 gears)
Track-lock dana 44 all new. From Gold hub to hub its new. (4.09 gears)
Electric vacuum assisted four wheel power disc brakes.
Quick ratio power steering. All steering components are new.
Interior has its original blue dash pad, ranger door panels and hounds tooth seat covers.
The seats have new foam and seat heaters.
Sound deadening material is in the doors, under the headliner, behind the seats and under the new carpet.
The bed has a one of a kind hard tonneau cover that is water tight. The inside of the bed is carpeted in the matching color of blue as the interior. It too is has been treated to copious amounts of sound deadening.
The tonneau cover is covered in black marine grade padded vinyl an is rated for 500 pounds.
So you can and your kids can drop the tailgate and sit on it, and have lunch after a Sunday drive or off road adventure.
This Bronco is rattle free.
All lighting is LED, including the KC headlights.
I have owned several broncos over the years. This one has been in my family for over 40 years. Original owner/purchaser was our neighbor.
Comes with all paper work and receipts. Stock steering wheel, two soft tops, and original owners manual.
With respect to the buyer/seller privacy I was trying not to list the price.
But do to the how many e-mails I am receiving and responding to already.
The price for the Bronco is $110k.
