ford man
This is a project that I bought from a member on here and will probable never get around to it so I thought I would see if some one else wanted to tackle it.It started life as a spring time yellow 170 6cyl and I have the title that matches the frame and the tag on the kick panel.What you see is what you get it has a dana 30 front and 9"rear no motor or transmission body is rough but could be built.The frame is very solid no visible rot.The front floor pan are rusty and need replaced the rear floor is decent.This bronco need a lot I understand but hey it is a u13 for 3500!
