I have been doing a frame off for the past 2 years. The frame has been blasted and painted with POR15 gloss black. The front and rear diff housings have been blasted and powder coated hammer tone. The front has a lunch box locker the rear has a Yukon, both with 456 gears. The front has chrome molly shafts. The rear has a new disc brake kit installed. All sitting on a 3.5 Monster Lift by Duff. Currently has a fresh 351w, aluminum intake, ceramic coated long tube headers, set up for a serpentine belt system. Setting behind the 351w is a new AX15 transmission with hydraulic throwout bearing. All this rolling on 35's with 15in 8 hole aluminum wheels. The body does not have the typical rust, so to speak. The bed is very nice. Needs the floor, and firewall. I have a complete floor pan assembly & new radiator support from Dynacorn. I have new inner fenders, the outers I believe are OK, I also have the cowl panels. The right rear 1/4 panel I've removed and bought a new one with the flare. I also have 3 our of 4 front and rear door jams with outer rockers. You'll need a hood or some sheet metal work as the previous owner built his own hood scoop. I also have the original hard top. No interior except for rear seat. I also am including a body rotisserie that the body is currently attached to. Please send me your email address only if you're serious about this vehicle which I believe could be one of the nicest once completed. I will then send you additional pictures and info. No shipping as this is quite large. I could probably help out or at least get this to you if you'd be willing to pay for my time, this could work.
