crawln68
- Joined
- Oct 8, 2004
- Messages
- 3,045
I have a complete Explorer motor swap kit for your Bronco. Here is what I have,
2000 Explorer motor with 70K miles. Brand new water pump.
2000 Explorer 4r70w 4x4 trans. Completely rebuilt with zero miles on it.
Advance Adapters tail shaft to mount a Dana 20 t-case.
Brand new Torque Converter from the shop that rebuilt the trans.
Sanderson P-head headers from the Bronco Hut.
New wiring harnesses and fuse block from Garry the EFI Guy.
Reprogramed PCM from Garry the EFI Guy.
I have all of the parts and accessories for the engine as you can see in the pictures . I even have the stock cast iron manifolds if you would rather run those. I have rebuild kits for the fuel injectors too. Everything that you need to swap this into your Bronco all in one "kit". $3000 for everything.
