77-302
I am selling my 1977 Bronco
For those new to the hobby, the 1977 is the last year of the original bronco.
Some say it’s the Best year as it came standard with several key options, the big bearing 9” rear axle, Dana 44 front axle, standard power front disc brakes, standard power steering, automatic transmission and a front sway bar. 1977 is the only year with integrated fuel doors as they were a requirement for 1977 safety standards.
https://www.dropbox.com/sh/wuyzic6r3bvs4qv/AAB7BQgxaSl4uPPhPvtD3B1ta?dl=0
I have the Marti report showing this unit was built late June 1977, (one of the last few hundred built before the plant retooled for the full size 1978)
I am selling because I have other projects.
This truck has a clean Michigan title and is registered with historic and rare 1977 half year Michigan plates. (available if the truck stays in Michigan).
We have enjoyed this Bronco since 2012. It has a solid body with no bondo.
It came from Mississippi. It drives 70mph on the highway with no shakes. I only drove it during summer months and it was babied. It needs nothing if you intend to drive it.
Vehicle has 83xxx original miles.
Notable updates include:
Engine 302
Professionally Rebuilt (2k miles ago)
Long tube headers w/ Stage 8 locking fasteners
Edlebrock performer aluminum intake
Fi-Tech Throttle body fuel injection with accumulator (enables dual tanks to be used)
Flow Kooler Water pump
New Jeff’s Bronco Aluminum Radiator
Ford Ranger washer fluid/radiator overflow tank
Ford Racing plug wires, valve covers and air cleaner cover (w/ K&N filter)
Vintage air conditioning with new condenser (blows cold)
3G alternator
Transmission
C4 (rebuilt by previous owner) Shifts great.
B&M deep sump aluminum pan
Transfer case
Completely rebuilt Dana20, all worn parts replaced
New Front driveshaft
Refreshed rear driveshaft with spicer dog bones
Exhaust
Long tube headers
Custom fabricated 2 into 1 Stainless with passenger exit and chrome tip
Walker quiet flow exhaust (sounds like a truck not a dragster)
Chassis/Suspension
New fuel lines
New fuel filler hoses
New Jeff Bronco Auxiliary tank with skid plate
New fuel caps
All new brake lines
Ford Thunderbird Front calipers and SS brake lines
2.5” Lift from Tom’s Bronco
New Steering box
New Drop pitman arm
New adjustable front panhard rod
New C Bushings and trailing arm bushings
New Sway bar bushings.
Steering and Drag Linkage Converted from “Y” to “T” (no more bump steer)
Interior/Exterior features.
Family cage with 4 retractable shoulder belts
Tom’s Bronco rear impact bumper with tire carrier (original tire carrier available with all hardware)
Aftermarket stereo with Rockford Fosgate speakers
Kick panel speaker pods from Bronco Hut
New retractable antenna
Rare underhood storage box (replaces leaky fresh air vent)
Rear speaker pods under seat
LED head lights
LED back up lights
LED third brake light in spare tire lug holes.
White bikini top will be sold with truck.
I have some other spare parts I'm willing to throw in if the price is right.
Several Pictures can be found here.
If you would like to see more, please ask. But also be patient, I have a day job and can only get pictures after hours. I'll do my best to check for questions as often as possible.
Engine 302
3G alternator
Transmission
Transfer case
Exhaust
Long tube headers
Chassis/Suspension
New fuel lines
New fuel caps
All new brake lines
New Steering box
New Drop pitman arm
LED head lights
LED back up lights
