Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 07/13/19, 10:01 AM   #16
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Man w/the plan..
Originally Posted by DirtDonk View Post
And regarding the bumpsteer 1strodeo, you still have not rotated your tie-rod up back into position to mimic the original. For now you are also dealing with a trackbar and draglink that are not as parallel as they could be with this setup, AND also more "tie-rod rotation" than you should be.
Loosen the three adjuster sleeves, grab the centerlink and rotate it "up" so that the Zerk fitting on the lower draglink end points up at a 60 degree angle (roughly up at the bottom of the radiator if it's still stock) and much of your other issue will disappear.
sprdv1 is offline   Reply With Quote
Old 07/13/19, 10:39 AM   #17
1strodeo
U15 Apprentice
1strodeo's Avatar
Fix,Drive,Modify,Repeat
Centerville, OH
Thanks everyone, hey Paul yes I noticed the zerk facing forward after I posted that pic, as I had read your post in a similar thread in Tech the day before. I'll get on that for sure, and order some of those sleeves. Do you still want to see the part numbers and calipers or are you & Jim pretty confident they're FSB/F150 spindles?
thanks again -Jeff
1966 LUBR, 351/4spd swap in progress, 2.5" SL, 1" BL, 31's Tonko
1972 U15, 302 3spd, 3.5" SL, 1" BL, 35's Frankie
1strodeo is online now   Reply With Quote
Old 07/13/19, 12:17 PM   #18
DirtDonk's Avatar
San Jose, CA
I'd still like to see pics. I haven't seen anything regarding the brake calipers themselves, and that would confirm things a bit more. The numbers would cement it.
So when you get a chance. No emergency, as you know you need the sleeves no matter what. So just for the FYI department.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is online now   Reply With Quote
Old 07/13/19, 12:29 PM   #19
1strodeo
U15 Apprentice
1strodeo's Avatar
Centerville, OH
Yes Sir, oh and by the way I KNOW for a fact I oriented the zerk when I installed the 3-way kit, my guess is the alignment shop did it but like you said even the pros arent always aware of how it should be.
Old 07/14/19, 08:38 AM   #20
1strodeo
U15 Apprentice
1strodeo's Avatar
Centerville, OH
Here are pix, number on spindle steering arm is 620170 -jeff
Click image for larger version
ID:	481955   Click image for larger version
Old 07/14/19, 03:09 PM   #21
DirtDonk's Avatar
San Jose, CA
Thanks. What do those numbers read out as? I'll check them against my known '76 F150 arms and we'll know.
They're for sure Ford brakes, but you probably knew that already.
Old 07/14/19, 03:14 PM   #22
1strodeo
U15 Apprentice
1strodeo's Avatar
Centerville, OH
620170, I looked on eBay and that is the number for the L spindle and 620169 is the R spindle for 78-79 Bronco/F150
https://www.ebay.com/p/78-79-Ford-Br...-75/2061609370
Old 07/14/19, 08:19 PM   #23
DirtDonk's Avatar
San Jose, CA
Cool, so not a "custom" tapered hole you're dealing with. Just larger than a stock EB so the sleeves should be just the ticket.
Old 07/15/19, 12:53 PM   #24
sprdv1
REBEL
sprdv1's Avatar
guaranteed to miss something like that for sure
Old 07/15/19, 12:54 PM   #25
sprdv1
REBEL
sprdv1's Avatar
Imma have to come up to ohio to help huh...
Old 07/16/19, 05:57 AM   #26
1strodeo
U15 Apprentice
1strodeo's Avatar
Centerville, OH
you're always welcome my friend, I'm at 1313 Mockingbird Lane in Mockingbird Heights
...decided to wait for the sleeves and boots before trying to rotate the zerk, especially since the tie rod (at least the left one) is flat against the steering arm, so wouldn't be able to get the tie-rod roll Paul was referring to
Old 07/16/19, 06:08 AM   #27
sprdv1
REBEL
sprdv1's Avatar
I really do want to hit that Michigan beach round up (silver lake), You could go too
Old 07/16/19, 01:34 PM   #28
jperry1290
jperry1290's Avatar
NorCal
I used these and they re perfect
https://www.barnes4wd.com/Tapered-St...ert_p_510.html
jperry1290 is offline   Reply With Quote
Old 07/17/19, 04:51 AM   #29
1strodeo
U15 Apprentice
1strodeo's Avatar
Centerville, OH
hey jperry that's good news!! I've got my sleeves (and new boots of course) on order...apologies for the thread hijack btw
Tags
steering, steering linkage, track bar
Page generated in 0.48818 seconds with 64 queries
