Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 06/15/21, 07:57 PM   #1
Cactus killer
Cactus killer's Avatar
Just because it works dosn't make it right Jason BC Broncos
BC Broncos 25th anniversary product number 8
Our new drain plug kit is a great addition to the line of products we offer.
The bung that comes in the kit can be welded into any one of your drivetrain components. This will allow you to drain automatic transmission pans that do not have an original drain plug or add a drain to the back or side of the rear end housing. The aluminum thread in plug has a recessed Oring, making it easy to get a good seal. It also has a magnet to remove any fine metal and helps you keep an eye on the health of your components. Made in Texas
https://bcbroncos.com/shop/bcb-origi...y-ford-bronco/
Click image for larger version
Name:	new drain plug installed 1k.jpg
ID:	525890   Click image for larger version
Name:	new drain plug 1k.jpg
Jason BC Broncos
Cactus killer is offline   Reply With Quote
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.46563 seconds with 72 queries
