Nothing Special
- Nov 25, 2016
- 804
The winch finally made it to the top of the list, so I now have that receiver mount winch! I started off with a Warn M8000 winch. Looking at internet reviews of the less expensive brands it seemed like almost everybody loved them, except the few people that had them fail to work when they needed them. I don't know if the Warn will really be any better, but it seemed like it was worth spending a little more for the reputation.
I also didn't feel like going with Warn's cheapest line (VR series?) for the same reason, but also didn't want to spend the money for Warn's more expensive lines. So the M8000 seemed like about the right value point for me.
I thought about either buying a ready-made cradle, or going the opposite way and making it all from scratch, but I decided to take the middle route. I bought a mounting plate and made my own from that. I cut down the ends of the standard Warn mounting plate to be just long enough to protect the ends of the winch, but to keep them out of the way of my clevis mounts. I bolted it to a piece of 2" square tubing (using 1/2" grade 8 bolts) and also welded the plate to the tube. Belt and suspenders!
The result ends up tucked up pretty high and tight, better than I expected. I was afraid it would look vulnerable to trail obstacles, but I don't think it'll be a problem much of the time.
It does stick up too high to be able to ride in the rear receiver. I can't swing the spare tire carrier closed when the winch is there. But that seemed better than compromising the mount strength and approach angle by cutting and welding to drop the plate lower than the top of the receiver tube.
I mounted the solenoid box right on the motor and ran the cables as short and tight as I could, with a quick-connect for the main power feed also attached to the mount (so it won't be plugged in while driving). I put a quick connect under the hood, and another in the back, so I can plug in at both ends with a relatively short power cable. And I used an isolator relay so the power lines aren't always hot.
OK, enough talk. Here are pics of it mounted in front (without the power cable connected), the quick-connect in the back (with the power cable connected) and the winch mounted in the rear (with the power cable).
Now I'm looking forward to going 'wheeling a little harder, and still hoping I never have to use it!
