1977 Bronco Parchment color question and progress on our 77 Bronco
64jmb
Hey All, Did we ever figure out the correct code for the 66-77 dash color for the bronco? Is it Lt. Parchment semi or Parchment semi? Same as 66 Mustang Parchment or 67-68 Mustang Light Parchment. I found som original lacquer in both need to know which one is correct?
Let me know thanks!
By the way here is the progress on my 77.
Frame repainted, all new floors.. moving right along!
rguest3
Here is how the Parchment with a Satin Finish turned out.
stout22
Athens, AL
I know my 76 with original paint looks like its a flat paint, no gloss.
The first picture is with the flash turned on. I'm not sure if this helps.
rguest3
Probably Light Parchment - Ditzler 22780 in a Satin Finish.
thiswildbronco
My bad - I should have finished reading thread.
I see you gave it as:
"Probably Light Parchment - Ditzler 22780 in a Satin Finish"
Cheers,
Doug.
That looks fabulous!!!
Do you happen to have the paint color reference and/or code for this?
I'm on the hunt for Parchment.
T H A N K S ! ! !
64jmb
64jmb
T H A N K S ! ! !
I used Lt. Parchment for the 67/68 Mustang. Looks almost identical. Scott Drake has it. L-4595.
64jmb
64jmb
77 Bronco more updates on completion
We have allot of the paint work and dash painted now. Just inside now. More to come. Body was all repainted all under the factory green as well and back on the frame now motor and trans installed.
