I am looking at will be my 1st cb this Saturday. I am 6'6" 250 and worried that it wont have enough room. Is it possible for these trucks to be comfortable for taller men? Serious inquiry. Thank You.
I agree with all of the statements above - we are similar - 6'-6" and I vary between 230 - 260...
I moved my seat mounting bolts back about 4" - makes a huge difference in leg room.
I bought the smaller steering wheel from WH - LeCarra 14" Thick grip - Love it. Had a 13" and it was a little too small.
Shifter on the column or auto - then it is a non-issue. If they installed a three speed floor shift the shifter can be bent a little to the right for more room. Or other manual transmissions will move the shifter more towards the center of the tunnel.
Seats - these vary widely so if the bronco you are looking at has seats that are not great for you - there are plenty of options. I went with a Corbeau Baja RS reclining suspension seat. I wish I had looked around - great looking seat but the bolsters are a little high / tight.
You can upgrade to a tilt steering column if need be to change the angle of the wheel - I did and I like it.
The place where I have found I wish I had more room is always at the top of the windshield - my seats are mounted pretty low and my field of vision is fine for driving but at traffic lights - not so much. You can look at the light reflection on the hood and usually see it change color or throw money at that as well and go with the view finder windshield - it moves the wipers to the bottom and give you two or three more inches at the top. It is too much work / cost for me to consider right now.
