Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 07/02/20, 08:23 PM   #16
broncobsession
Not a bronco guru
broncobsession's Avatar
All Over the Place
What a great thing to do for your brother in law? Do you have a daughter my son could marry? I’ve got a bronco that needs building I’d keep both.
Always looking for the next project.
broncobsession is offline   Reply With Quote
Old 07/02/20, 08:34 PM   #17
bulletpruf
San Antonio
It's actually a good deal for both of us -- I enjoy wrenching on old rusty cars and trucks, so I'm having a lot of fun with this.
Yes, I have a daughter, but she's only 7. May want to check back in 20 years.
Scott
'69 Bronco, 302, 3 sp; '66 Fairlane GT convt, 428, 4 sp; '68 GTO convt, 455, TH400; '71 Javelin road race project, 401, 4 sp; '72 Alfa Rome GTV, 2.0, 5 sp
bulletpruf is offline   Reply With Quote
Old 07/03/20, 09:39 PM   #18
bulletpruf
San Antonio
Made some progress on the '72 - it lives. Here's a recap -
Changed oil and filter.
Pulled distributor.
Primed oil pump; got oil to all of the rockers.
Turned over easily with a socket on the balancer bolt. I don't think it was stuck.
Tried to spin it over with starter and all I got was a click.
Removed starter; it's a reman that didn't look too bad. But when I disassembled it, armature was broken/worn through so I installed a new starter.
Also swapped out starter wire and battery cables for spares that I had in the garage. Cleaned all connections and smeared on some dielectric grease.
Then spun the engine over with valve covers off and verified that all valves were opening and closing.
Valve covers back on.
Installed dizzy. Cleaned points. Got timing in the neighborhood by pointing rotor at #1 terminal on cap. Installed new plug wires.
Plugs cleaned, gapped, reinstalled.
Installed jumper wire between coil and positive terminal on battery.
Checked for spark - good.
Ran fuel line into gas can.
Primed fuel pump.
Fired right up! It even idled after I blew a monster mouse nest out of the tailpipe.
Video to follow.
Scott
__________________
Old 07/04/20, 01:17 PM   #19
bulletpruf
San Antonio
https://youtu.be/aPf4vjqGKFQ
Old 07/06/20, 06:43 PM   #20
bulletpruf
San Antonio
This one followed me home today - 67 U15 roller - south Texas Bronco, solid frame and tub with VIN tag and title. Kept the doors and will sell the rest.
EDIT: Just decoded. Original color was peacock blue. DSO - San Jose.
Click image for larger version
ID:	503932   Click image for larger version
ID:	503933   Click image for larger version
ID:	503934   Click image for larger version
Old 07/07/20, 07:20 AM   #21
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
on a roll ain't ya..
sprdv1 is offline   Reply With Quote
Old 07/07/20, 03:28 PM   #22
rhino2104
rhino2104's Avatar
THE MONKEY MADE ME DO IT!
Round Rock, TX
Not to be too pesky, but how much would you be asking for this one?
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car, horsepower is how fast you hit the wall, and torque is how far you take the wall with you.
rhino2104 is offline   Reply With Quote
Old 07/07/20, 03:36 PM   #23
bulletpruf
San Antonio
Darn good question. I really don't have a good feel for value, so my plan is to put it on eBay with a $1 starting price and no reserve.
Old Yesterday, 02:09 PM   #24
bulletpruf
San Antonio
I listed the '67 for sale in the member's classifieds here.
Thanks,
Scott
Old Yesterday, 04:25 PM   #25
gnpenning
gnpenning's Avatar
Mt
Which one did you decide to build?
Your bronco locater is working pretty good..
66. U13, 6 cyl, 3 spd, uncut.
70. 302, 3 spd, Duffy 3.5 lift. Future project
74. Dirty blue. 302, C4, ps, Ford frt disc, 4:30. Locked
76. 302. C4. Future project.
gnpenning is offline   Reply With Quote
Old Yesterday, 04:59 PM   #26
bulletpruf
San Antonio
Gonna build the '68. The '72 needs too many panels replaced.
Yeah, I have scrounged several in pretty short order. Helps to have a trailer, winch, and some $ available.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright 1996-2020 All rights reserved. Privacy Statement
Page generated in 0.48493 seconds with 66 queries
