Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 01/04/21, 11:56 AM   #1
Cactus killer
Cactus killer's Avatar
Just because it works dosn't make it right Jason BC Broncos
BC Broncos 25th anniversary product number 2
Our new internal hood release is a great upgrade to your Bronco this will secure your engine and help prevent someone from stealing it. We know how much Broncos are going for these days, so securing them is even more important than ever. This brand new polished billet aluminum design incorporates the cable mounting and safety built in. This will give you more room to add extra coolers, fans or ac condenser and clean up the grill area. We designed this piece to have all of the mounting, cable mount and spring completely contained within the one piece.
To make sure that even if the pivot pin were to come loose it could not come out or release the hood, we also use a ultra strong stainless steel bolt rated at 65,000 psi. We also designed the mechanism so the spring is not visible. From the front of the Bronco.
The cable is mounted in the dash using parts that look stock, if you removed a stock switch you could reuse that hole or drill a new one. The kit comes with the mechanism, cable, bezel, knob with removable insert and stainless steel hardware.
https://bcbroncos.com/shop/interior/...-hood-release/
Click image for larger version
ID:	515384   Click image for larger version
ID:	515385   Click image for larger version
ID:	515386   Click image for larger version
ID:	515388   Click image for larger version
Jason BC Broncos
Cactus killer is offline   Reply With Quote
Old 01/05/21, 08:58 PM   #2
AUSTX
Austin
Very nice!!!
AUSTX is offline   Reply With Quote
Old 03/02/21, 07:49 PM   #3
Cactus killer
We have added two additional offerings for this item.
We are still considering them item #2
https://bcbroncos.com/shop/interior/...se-66-67-knob/
https://bcbroncos.com/shop/interior/...h-lokar-cable/
Jason BC Broncos
Old 03/16/21, 11:17 AM   #4
Rustytruck
Rustytruck's Avatar
honest the bolder ran under me
El Monte CA
one with a pull knob one with a pull lever. how hard is the pull? a couple pounds or a really hard tug?
1974, stock 302, C4, BFG KM2 33x12.5x15, 8in rim, detroit rear, trutrac front 4.11 gearing, Warflairs,2.5" lift, chevy disc conversion, Hydraboost, owned since Christmas Eve 1977
Rustytruck is offline   Reply With Quote
Old 05/01/21, 08:02 PM   #5
Cactus killer
When the hood spring and bumpers are adjusted correctly the pull is very easy, only 18lbs.
We tested it using a fish scale.
Jason BC Broncos
Old 05/05/21, 04:21 PM   #6
Rustytruck
Rustytruck's Avatar
El Monte CA
Thank you 18 lbs isnt too bad. third option a pull handle from the factory parking brake?
Old 05/07/21, 10:02 AM   #7
76YETI
76YETI's Avatar
KC METRO
How far does the knob pull out...I no longer use the auxiliary tank switch, but have a roll bar kinda in the way.
76 Ranger U151, 33"BFG KO2 on Eagle 058s 15x10, 95 5.0 HO Motor, 96-01 Serp Conv, C4, 1" BL, New Stock Suspension. Fabbed rear tire carrier/bumper. Corbeau XRS Seats.
76YETI is offline   Reply With Quote
Old 05/07/21, 10:20 AM   #8
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
VERY slick!
tasker is offline   Reply With Quote
Tags
bc broncos, hood, hood latch, hood release
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.49616 seconds with 70 queries
