Thread Tools
Old 05/14/19, 08:21 PM   #1
DEEPWOODS
DEEPWOODS's Avatar
Fayetteville
ARB Ford 9 Old type need help
So my Arb is leaking where the copper pipe goes in the ring that has the 2 o ring seals . Part is no longer made as its the old first design. It has almost never been used as its been in my bronco in the basement for 12 years . Looks like it was silver brazed that didnt take or hold . Can anyone tell me if it is brazed on the inside of the ring ? Looks like I will need to pull the bearing of to get to it . Thanks Keith
File Type: jpg D8858774-E449-493A-8EF2-10C3A90227C1.jpg (97.5 KB, 72 views)
File Type: jpg 4019972D-78A5-4EEE-87E9-563BF6BBF699.jpg (90.3 KB, 67 views)
DEEPWOODS is online now   Reply With Quote
Old 05/14/19, 09:45 PM   #2
SteveL
Huge chevy guy
SteveL's Avatar
66 &72 w/351, 4spd, 4whl disc.
Hawthorne, ca
Maybe try and contact arb. Might get lucky
SteveL is offline   Reply With Quote
Old 05/14/19, 09:55 PM   #3
DEEPWOODS
DEEPWOODS's Avatar
Fayetteville
I did and they don’t care. Told me to buy a new design arb . If I can’t fix it I won’t be getting a ARB. I will go with a Zip Locker
Old 05/15/19, 10:38 AM   #4
welndmn
welndmn's Avatar
Well Done Man!
Concord, CA
Yes, that is just a brazed on fitting.
You can disassemble the locker, heat up that tube and slide it out, then clean it and flux it and re braze it.
It's common to fix those on ARBs, so if you google around for soldering on the seal housing you should find some tips.
Mark, 71 bronco with loads of go fast parts held back by a 200hp engine.
42 inch marshmallows.
welndmn is offline   Reply With Quote
Old 05/15/19, 10:30 PM   #5
661buster1963
661buster1963's Avatar
mediocre at everything master of none
bakersfield CA
It’s a shame ARB didn’t care. I’ll file that away if I ever want a selectable locker, not likely ARB
1968 bronco, 351W flat tappet, NP435, dana 20 twin T shift, dana 44 with disc, 9" 31 spline big bearing , frame and sheet work for frame off restoration. ECD about 2 years ago, still not done.
661buster1963 is offline   Reply With Quote
Old 05/15/19, 10:59 PM   #6
nvrstuk's Avatar
20 gears forward...no reverse!
WA
I would REALLY like to know which ARB rep's DEEPWOODS talked to because I've ALWAYS had excellent service from ARB... I have bought multiple ARB's from them, repaired several, helped others get parts from ARB and have always been treated with utmost respect and concern... that being said, I do know that 4 of the "long-term" employees at the local ARB service center (120miles away) left and run a 4x4 store...all the employees there now are "newbies"...
Here's hoping you have better luck...
Can I ask which ARB "store" you were dealing with...
Strrroker powered... 418 cubes, 518 HP, SEFI, EDIS, Still 20+ forward gears...CB build:http://classicbroncos.com/forums/sho...d.php?t=278607 NWCB Stroker/SEFI/EDIS/4r70W/KluneV/TrueHi9 build: http://northwestclassicbroncos.com/s...n-to-SEFI-EDIS
nvrstuk is offline   Reply With Quote
Old 05/16/19, 07:44 AM   #7
bigmuddy
bigmuddy's Avatar
Consensus is not science!
Marthasville MO
eBay: bjf68
Ditto on what nvrstuk said.
75 EB, 35" tires, EFI 5.0 with Explorer stuff. ARB/ Aussie locker, ZF tranny, 4.56 gears, twin stick, 2.5 BC lift, Cage long arms and dual shock kit,Ghetto fab hydroboost with disc brakes,yada,yada,yada!
bigmuddy is offline   Reply With Quote
Old 05/16/19, 10:01 AM   #8
welndmn
welndmn's Avatar
Well Done Man!
Concord, CA
I don't think it's that ARB does not care, they just do not make the part anymore as the design changed.
Old 05/16/19, 04:29 PM   #9
nvrstuk's Avatar
WA
Deepwoods...if you want to get rid of that ARB, let me know. thanks
Old 05/19/19, 12:34 AM   #10
DEEPWOODS
DEEPWOODS's Avatar
Fayetteville
Not ARB store it was ARB USA tech and yes the housing with the copper pipe coming out on the side is no longer available .I have it out and apart now going to try the fix on pirate where you drill it out and use brake line and part of the old copper tube and braze them together as it has to be the small copper at the end at where the nut is.
Old 05/21/19, 08:08 PM   #11
AGGRV8D
AGGRV8D's Avatar
So Cal
I'd also be interested if you ever decide to get rid of that locker. Pretty sure ARB doesn't make one for the old sb 9" anymore.
AGGRV8D is offline   Reply With Quote
Thread Tools
Page generated in 0.34747 seconds with 63 queries
