Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 07/09/19, 04:20 PM   #1
JeffG
JeffG's Avatar
San Antonio, TX
eBay: 1969Jeff
Kick Panel Speaker Pods - Different Take
I recently put together a set of speaker pods modeled after the ones built by JGZ. I didn't go all fiberglass and I'm glad I didn't as I now know how much effort goes into making fiberglass look smooth.
I like to build things and knew that I could use a little more space since I haven't ran a parking brake in over a decade. I didn't have a full plan in mind when I started it just sort of grew out of necessity and what made sense.
I started with two sets of MDF Speaker Rings purchased off Amazon. I wanted 6.5" speakers so I purchased a set of rings to fit those and a set of 8" rings for the base. I used some left-over quarter round trim to build the spacers between the two rings. I made one shorter than the other to angle the speaker a little toward the passengers.
Click image for larger version
ID:	481673   Click image for larger version
ID:	481674   Click image for larger version
ID:	481675   Click image for larger version
JeffG is offline   Reply With Quote
Old 07/09/19, 04:23 PM   #2
JeffG
JeffG's Avatar
San Antonio, TX
eBay: 1969Jeff
I used a hot glue gun and panel nails to hold them in place. After watching a few YouTube videos of how to fiberglass speaker pods, I wrapped both in a piece of thin fleece.
Then a coat of fiberglass resin and some pieces of fiber mat and they started taking shape.
ID:	481677   Click image for larger version
Old 07/09/19, 04:27 PM   #3
JeffG
JeffG's Avatar
San Antonio, TX
eBay: 1969Jeff
I didn't get a good picture of it but I used some strips of aluminum to go from side to side on the larger 8" ring to create a mounting point.
After the fiberglass set up and sanded down a bit I applied some body filler and began sanding them down with an air orbital sander (Wear a good mask!!)
ID:	481679   Click image for larger version
Old 07/09/19, 04:32 PM   #4
bamabaja
The Shoals
Very nice !
bamabaja is offline   Reply With Quote
Old 07/09/19, 04:33 PM   #5
JeffG
JeffG's Avatar
San Antonio, TX
eBay: 1969Jeff
I currently have my front passenger area and kick panel covered with Dyna Mat so I knew I wanted to cover most if not all of the kick panel area. I plan on ordering a Bronco script rubber mat for the floor area.
So next using cardboard I made templates of both kick panels and used some 1/4" wood paneling to make the cover and speaker pod mount.
After a trip to Joann's Fabrics I picked up 1 yard of black vinyl and some stuffing/padding (can't remember what that is called but it was fairly thin).
ID:	481681   Click image for larger version
ID:	481682   Click image for larger version
Old 07/09/19, 04:35 PM   #6
JeffG
JeffG's Avatar
San Antonio, TX
eBay: 1969Jeff
Forgot to mention after the sanding I sprayed the speaker pods with some black Dupli Color rattle can bed liner.
This is the part I was mentioning earlier about getting the fiberglass perfectly smooth!! Good thing for the textured paint to help cover up the imperfections because I got tired of sanding.
Old 07/09/19, 04:38 PM   #7
JeffG
JeffG's Avatar
San Antonio, TX
eBay: 1969Jeff
I didn't get any pictures of the passenger side panel but it was basically the same with the exception of making room for the heater box inlet.
I haven't had a heater in several years either but I plan on putting one back in soon so I hope I left enough room for the inlet. It definitely won't fit the OE style but I believe it will work with the improved inlet tube like this:
https://www.tomsbroncoparts.com/prod...ord-bronco-new
Old 07/09/19, 04:43 PM   #8
JeffG
JeffG's Avatar
San Antonio, TX
eBay: 1969Jeff
I'm including the Polk Audio speakers I went with and pics of the finished product.
I thought about a few different ways to attach these but what I ended up doing is mounting the speaker pods to the panels and installing 2 Riv-Nuts in the kick panel. I also had to make holes to attach the door straps back on and they are very sturdy.
On the backside of the Riv-Nuts I put a dab of silicone to help with any moisture that might try to get in.
ID:	481657   Click image for larger version
ID:	481658   Click image for larger version
ID:	481659   Click image for larger version
Old 07/10/19, 05:23 AM   #9
bigmuddy
bigmuddy's Avatar
Consensus is not science!
Marthasville MO
eBay: bjf68
Good work, looks great!
I love when people make their own parts! Need to see more of this on the bronco forums!
75 EB, 35" tires, EFI 5.0 with Explorer stuff. ARB/ Aussie locker, ZF tranny, 4.56 gears, twin stick, 2.5 BC lift, Cage long arms and dual shock kit,Ghetto fab hydroboost with disc brakes,yada,yada,yada!
bigmuddy is offline   Reply With Quote
Old 07/12/19, 05:50 AM   #10
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Turned out great Jeff. Took some time on that, but well worth the effort it looks like
sprdv1 is offline   Reply With Quote
Old 07/12/19, 09:26 AM   #11
rydog1130
rydog1130's Avatar
Bronco Math: time+money=bronco and if time=money then money+money=LOTS OF MONEY
Kalamazoo, MI
nice job! I built my rear speaker enclosure and its not extremey hard but time consuming as you probably found out. Now wait for everyone messaging you to build theirs next
1968 Bronco, 289, dana 30, C4 auto, stock ps, MSD ready to run ignition, centech, desert khaki....everything else stock: 1970 Bronco 302 3 spd, Koenig PTO winch : 1990 AM GENERAL HUMVEE 2009 Dodge Challenger R/T : 2008 Honda Element (aka Bronco Concept) : 1968 Dodge Charger in pieces
rydog1130 is offline   Reply With Quote
Old 07/12/19, 02:22 PM   #12
svastano
svastano's Avatar
Pulaski, PA
Look great!
svastano is online now   Reply With Quote
Page generated in 0.39603 seconds with 63 queries
