Go Back   ClassicBroncos.com Forums > Classifieds > For Sale - 66-77 Bronco Parts
Closed Thread
Old 11/03/19, 07:02 PM   #1
77broncodriver
77broncodriver's Avatar
Prunedale, CA
Ford EFI System
City: Prunedale
Price: $1000
Hey all,
I am wanting to sell my ford efi system to upgrade to a more tune-able system as I want to build my engine up farther, possibly build a stroker.
What is included:
Explorer upper/lower intake
Throttle body
Intake tube
All needed sensors
Stock MAF/ 19lbs injectors and a larger MAF calibrated for 30lbs injectors and the 30lbs injectors (I have heads/cam so upgraded to larger injectors)
MSD ready to run billet distributor (the tfi unit on this is far more reliable than the ford unit)
Throttle cable
Fuel rail
A9L computer? I have the auto trans computer, I think this is the one.
RJM engine harness
I am probably missing a few things but you would just need to get a fuel pump and plumb a return fuel line and you will be ready to go! I might actually have the in line fuel pump that I took off when I got an EFI fuel tank. If I can find it then you will just need to plumb the return!
I still have it all on the bronco so if anyone in the area wants to hear it run on my bronco and take it for a drive I will keep it on until I find a buyer.
You can reach me on here or call/text me at (831) 809-2746
Thanks,
Evan
Click image for larger version
1977 - 306, Edelbrock Pro Flo 4, 4r70w, D20, D44, 9", 3.5/2.5" sl, 2" BL, 35's
77broncodriver is online now
Old 11/03/19, 07:26 PM   #2
JGO
Originally Posted by 77broncodriver View Post
Hey all,
What is included:
Throttle body
Intake tube
All needed sensors
Throttle cable
Fuel rail
RJM engine harness
Thanks,
Evan
In my opinion the best most tunable system is close to what you already have! EFI GUY out of Colorado will send you a tuning setup and work on your tune in the evenings sending improved files every day until its perfect! The best performing engine I have built utilized a similar Mustang based computer. The whole process and chip cost very little. I ended up at around 430HP/550ft lb of perfect idling power!
JGO is offline
Old 11/03/19, 09:07 PM   #3
77broncodriver
Prunedale, CA
I have talked with EFI Guy about tuning mine to dial it in and that is still on the table, but I really like the idea of being able to mess with the tune myself with the new Edelbrock EFI system.
If no one wants this setup I will probably just stick with it, I am just interested in trying some new technology.
Old 11/04/19, 02:20 PM   #4
BanditBronco
BanditBronco's Avatar
Bingo!
Mesa, AZ
You can keep the system you have and run a Megasquirt PNP computer and tune it yourself with free software. The computer plugs right into your harness but has 0 stock ford stuff inside. It changes to a speed density set up.
351W, 4R70W, Atlas 2, 3.5 inch lift 1 inch body lift, full cage, suspension seats, discs, 37 12.50's, full widths, nics, nacs
BanditBronco is offline
Old 11/09/19, 08:53 AM   #5
fordtrucksrule
fordtrucksrule's Avatar
SoCal Highland
You can go to https://www.moates.net/quarterhorse-...rds-p-199.html and get the quarter horse chip and plug it into your computer and use your laptop with binary editor http://www.moates.net/binary-editor-p-213.html?cPath=63 and tune your engine that way. the quarter horse chip is 250$ and the key for binary editor isn't that bad either.
351w with a rv cam. pumping 300ft./lb torque at 2000 rpm and 160 hp at 3500 rpm to the ground with 4.11 and 35" tires ZF Transmission and a StAk 3 speed t case 133:1 crawl, full family cage, rhino lined tub.
fordtrucksrule is offline
Closed Thread
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright 1996-2020 All rights reserved. Privacy Statement
Page generated in 0.44728 seconds with 68 queries
