Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 08/16/16, 11:33 AM   #1
jduffent
jduffent's Avatar
Bronco born and raised
Knoxville, Tennessee
James Duff Torque Tamer Axle Wrap Bar
With low-geared axles and high torque engines, soft long-travel leaf springs can distort under power—this can cause damage to springs and break u-joints. Ordinary long tube, fixed mount traction bars limit travel as the rear axle cycles up and down because the axle also needs to move back and forth. Our new traction bar has a “V” frame designed center link for strength and utilizes a specially designed shackle to eliminate axle wrap. The bar runs between the mufflers, paralleling the driveline; protecting it. It also maintains proper u-joint and CV angles under power. The main bar attaches to a high clearance cross-member and shackle. The cross-member mounts up between the frame rails and helps protect your CV joint and output shaft from trail obstacles. Compatible with our Dual Exhaust system; other exhaust systems may require modification. Welding brackets to the differential housing is required. If you have a '77 Bronco or a later model 9" axle housing make sure you select the torque tamer for a '77 Bronco.
NOW OFFERED IN MIDNIGHT BLACK POWDER COAT
Completely eliminate U-Joint failure
Stop axle wrap in its tracks
Doesn't compromise suspension travel
No DIY or Engineering required comes fully powder coated and ready to install
This design works great on or off-road, does not bind up like others on the market
Only welding required is to the axle, leaving the guesswork to us
Last year we beefed up the design for Broncos with hotter motors and heavy right feet. We are confident that our Torque Tamer can handle the rowdiest of Bronco builds.
These are on free shipping through cyber monday! 11/26/19
'66-'77 Bronco - https://www.dufftuff.com/Torque_Tame...nco_p/5326.htm
As much as we believe in our own products and think they are great, customers pictures and testimonies are far more compelling. We encourage y'all that are using this product to share your install tech and/or pictures here.
Suzy
http://www.dufftuff.com
The Bronco Specialists since 1967
865.938.6696 m-f 10-6 EST
Now: Knoxville, Tennessee (Exit 110 off 75)
jduffent is offline   Reply With Quote
Old 09/17/16, 07:46 PM   #2
Monster Mike
Monster Mike's Avatar
always innovating constantly evolving
Knoxville, TN
I'll be making a YouTube video soon on how great this product works and how painless the install is.
The Best Early Bronco Anti Wrap bar bar on the market!!
Product and Warehouse manager at James Duff Inc. The Bronco Specialist since 1967. You want Quality American made Bronco parts? Then give us a call at 865-938-6696 or check us out at dufftuff.com James Duff Now in Knoxville, Tennessee. Open 10-6 Mon-Fri EST. YouTube channel - Bronco Garage
Monster Mike is offline   Reply With Quote
Old 09/18/16, 12:31 AM   #3
bronconut73
bronconut73's Avatar
How did you do that?
Orlando
Hell yea!
'73, 3.5" sl, XL RS9's, F-250 mounts, Duff long arms, 1" bl, 35" MTZ's, C-4, twin sticked, P.S., built 351W, Exp Serp, F&R Detroits, 4.11's, chromo axles, 11 leaf packs, SuperJoints, Chevy front disc, BC rear disc, BC Vintage a/c, Scat Procar 2K seats, Alpine/Pioneer, Bear, Cobra 148 GTL/Texas Star.
bronconut73 is offline   Reply With Quote
Old 01/09/17, 06:53 PM   #4
Monster Mike
Knoxville, TN
Bringing a 78 in this week to test fit all the components and make sure its ready for those Big Bronco guys. Sometime this spring I will make a youtube video of us installing one in Hobby Horse. Hobby is a great candidate because of its healthy 392 SVT crate motor, 4.56 gears, terra low dana 20, 36" swampers and 5.5" leaf springs. Its a great all around Bronco that will see some great benefits to this product. We definitely will be getting some before video too!
Old 11/23/19, 11:11 AM   #5
MeyerzBronco
MeyerzBronco's Avatar
Jupiter, FL
Have you done this video yet? Will this hang up on the rocks?
1969 Bronco 351W Lightning; Duff Monster Lift; 35"; 6R80; Atlas II
MeyerzBronco is offline   Reply With Quote
Old 11/23/19, 11:52 AM   #6
Monster Mike
Knoxville, TN
Not yet but it is on our production schedule for 1st quarter of 2020. The torque tamer does parallel the driveshaft so if you are going hang this up on rocks you are also going to have issues with the driveshaft.
Old 11/24/19, 12:54 PM   #7
jmangi62
jmangi62's Avatar
Hasta la vista,baby!
Omaha
How much do they cost? They're on my Xmas list.
jmangi62 is offline   Reply With Quote
Old 11/26/19, 02:23 PM   #8
Monster Mike
Knoxville, TN
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Copyright 1996-2021 All rights reserved. Privacy Statement
Page generated in 0.51192 seconds with 73 queries
