lomarker
- Joined
- Nov 13, 2016
- Messages
- 7
Hi -
Searched around a bit but couldn't find the answer. Leaking carburetor brought me to the engine compartment for a rebuild on what I believe to be the stock 2100. New to automobile carbs, but gonna give the rebuild a go.
Wanting to swap out the stock air filter assembly for a simple round unit. I don't have the hose or cold intake assembly. Brings me to hopefully a couple easy questions :
1. There is a hose connected to the rear of the stock unit that runs to some sort of can below the passenger side floor board - can't figure out what it is. The second hose coming from the can is blocked off. What is the can and what do I do with this hose if I go to a round unit?
2. There is a also a breather hose (I assume) from the stock assembly with a short hose that goes to the back of the block. Again, what do I do with this hose if I go to a round unit?
Thank you in advance.
I'll get some signature info in - but '74 with 302, NP435, NP205, 3" lift.
