71 CA Bronco
- Nov 25, 2015
- 761
OK, I'm having a heck of a time getting cowl assembly and floor assembly where they need to be. Thom aka Bronco Guru came over last week. BTW - Thank you Thom. We couldn't get the floor to match up with the cowl fire wall because the edge of sheet metal was hitting the front floor brace. I think I resolved the problem by pulling the body off again and sliding the cowl sections over the front floor brace. We now have the floor sections fitting well with sheet metal screws.
The current issue at hand is that the door width between each sheet metal piece (where weather stripping goes) is not wide enough. I've been given 35.3" and 35.5" as the rough dimensions prior to hanging door posts. I have roughly 35". Do I need to just spread this with a bottle jack? If I do, then I'm concerned the holes in the bottom of inner kick panel to inner rocker will be off. Otherwise, I may need to cut the bed off and slide it back about 1/2". If I go this route I'm not sure the bed will allow for that much adjustment? Scratching my head on this one.
